Wtb n13 exa fwd pulley aka harmonic balancer and thermostat housing
I need the brackets you use to lift motor with crane, also need to find a single belted harmonic balancer, also should I be running the bracket from block to inlet manafold?
Thanks nick
Posted on: 2012/3/17 6:37
Edited by supafatto on 2012/3/18 12:18:52
Edited by supafatto on 2012/3/18 21:19:17
Car free
Re: Wtb ca18det stuff
From Sydney, Australia
The bracket for the intake manifold is for crash safety not really required to hold the plenum
up. The two supports on top will do that.
As for lifting points the plenum is fine and hooking under any 8mm or 10mm bolt will be fine on the exhaust side.
Posted on: 2012/3/17 8:30
Yeah I don't have the bracket on the inlet, anyone got a spare
Posted on: 2012/3/17 8:40
Car free
Re: Wtb n13 exa fwd pulley aka harmonic balancer
Needed asap as now I'll be waiting on this so I can mount my motor so I can finish cooling setup and move on to paint
Posted on: 2012/3/18 12:20
Car free
From hastings,vic
got the bits here nik
Posted on: 2012/3/19 1:13
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
Re: Wtb n13 exa fwd pulley aka harmonic balancer and thermostat housing
Thanks TOMOZ ! Anything u need it should be called
Posted on: 2012/3/19 6:23
Car free
