Ute under cab chassis rails
Not too shy to talk
From brisbane australia
Hey all
Haven't been able to find much on this topic
Under the floor at the front of the cab there is the two rails and mine are in a bit of a sad state just wondered if there's replacements available or if people fabricate new stronger ones ?
Cheers
Posted on: 2012/10/5 3:32
Re: Ute under cab chassis rails
From Geelong, Vic
cant say ive ever seen them available. usually they are only replaced (with rust free ones from another 1200) if the originals are rusted out, or stronger ones made if the rest of the body/chassis is being strengthened
Posted on: 2012/10/5 3:53
pretty much what PIGDOG said. Just find another old 1200 with some half decent rails, from memory the rails under the cab are all straight so you should just be able to use a straight bit of rail from any 1200, possibly the 120y's too? but im not sure.
Posted on: 2012/10/5 4:14
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
My brother in laws was rusted out laser cut and pressed we ones to original shape out of 2.5mm and put new floors while we was there. Pretty big job
Posted on: 2012/10/5 4:29
datsun a15 ute
They Arnt straight the bend up at the front following up the bottom of the engine bay
Posted on: 2012/10/5 4:30
datsun a15 ute
yeah thats what i though. I thing they have slight bend somewhere along the line though? or could be a coupe. buggered if i can remember haha
Posted on: 2012/10/5 4:47
1200 Ute - Mild A12
From SA
Just sleeve over the original ones like I have done with mine.... C section tube and seem weld.. pretty simple to do !!
Posted on: 2012/10/5 8:21
Not too shy to talk
Mine aren't totally rusted more so dented very badly so welding a section around them might be the easiest option
Thanks all
Posted on: 2012/10/5 8:39
