« 1 ... 3 4 5 (6) 7 8 9 »
Re: Toying with oot
From Adelaide Hills
Its rough but getting there.
Was very happy that the exhaust manifold off the rx7 fitted... just... has about 3mm of clearance against the steering box.
And I'm hoping the oil cooler behind the rego plate wont stand out too much but all seems to be going smoothly so far. Just wish I had more time to work on it. Also wish it was in my own shed and that I had a shed, instead of one on the other side of town.
Posted on: 2013/1/28 10:22
Edited by lightload on 2013/1/28 11:31:05
Re: Toying with oot
Paint the.cooler black.
Posted on: 2013/1/28 10:30
Re: Toying with oot
From Adelaide Hills
One day I'm gonna build a show car.... that day is not in the foreseeable future. So instead I build an ugly trans tunnel.
Oh and my tail shaft has arrived. Looks beefy.
Posted on: 2013/2/11 10:29
Re: Toying with oot
I did my own trans tunnel a while ago and it is no easy task. I'm more than happy with it tho. What material are you using there? Looks like .8?
Nice work on slotting the engine and box in
Chuck some decent plates on the gb mounts inside to spread the load out.
I know what its like doing work out of someone elses shop/shed thats ages away but keep chugging away mate...
Keep up the good work
Posted on: 2013/2/11 10:51
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
Re: Toying with oot
From Adelaide Hills
Thanks mate.
Material is a little thick about 1mm I think, a friend makes aftermarket sumps and works at a truck body shop so grabbed some "semi galvanized" sheet out the bin for me and put a few bends in it to get me started. Yeah got some 50x50 washers to weld nuts to that will be tacked to the floor.
Posted on: 2013/2/11 12:30
Re: Toying with oot
From Adelaide Hills
Motor is in for final time I hope.
Tunnel took way longer than expected but once painted it looked a lot better than I thought it was going to.
Still need to do clutch pluming and make exhaust but almost all connections are done and its ready to turn over with some water and oil.
Was very tempted to start it tonight but not sure about db levels with just a manifold on a twin rotor in a shed.
Kinda spewing I didn't get it finished as I will be cutting down some 8m gums around the house next weekend and probably wont have a chance to get it finished.
Posted on: 2013/2/17 9:48
Re: Toying with oot
From Adelaide Hills
Its alive...
My exhaust sounds poo, got water leak from radiator hose that's on a angle. Oil leak from copper pipe weld that wasn't hot enough and needs a tune... but it starts first time and runs with a bit of choke.
Posted on: 2013/3/3 11:19
Re: Toying with oot
Good stuff, minor issues you will overcome easily IM sure
Posted on: 2013/3/3 20:50
Re: Toying with oot
From Adelaide Hills
Finished and loving it.
Exhaust sounds killer now.... for a rotary.
Goes awesome, needs a tacho and carpet. Doesn't feel like it needs a tune but haven't checked plugs yet.
Stoked with the ease and result of this build.
Downside is the front is now too low.
Posted on: 2013/3/12 11:48
Re: Toying with oot
Nice work mate!
Has been good watching this build progress, i love the work!
Too low in the front, thats easy fixed! Lower the back more :P
Would love to see some vid of the car in action!
Posted on: 2013/3/12 21:37
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
