ute diff into 120y sedan
From Townsville, Qld
Why didn't you guys remind me it was a major stuff around to put a ute h165 into a sedan? I'm not having a productive afternoon that's for sure, my current h150 is stuffed and the spare center appears to have some rust on the teeth and clearences about the same :/
Posted on: 2013/9/20 8:52
Re: ute diff into 120y sedan
Did you ask?
H165 center wont fit in a h150 housing
Posted on: 2013/9/20 9:15
That's not what I'm doing, I'm talking about the fact that the sedan housing has a shock mount and utes don't
Posted on: 2013/9/20 9:30
From penrith,sydney,aus
Its not hard at all, take a complete Ute diff,weld some threaded rod where sedan shock mounts go, make a longer rubber hose and your done, not hard at all in retrospect
Posted on: 2013/9/20 11:07
2 door 1200 sedan project l20b stroker
I had the mount for the brake line splitter moved across. Utes/coupes/ wagons mount the shock off the bottom sand which plate of the springs if that's where you were implying I weld this rd to Shaun.
Posted on: 2013/9/20 14:15
The sedan shocks mount onto the back of the diff tube,I welded mine in the same place
Posted on: 2013/9/20 23:16
Ah I see, and then you just riate the bottom 90 degrees and slide it on. Sitting about 30mm from the tube with those loads only being supported by one side doesn't worry you? I like to khanacross and stuff
Posted on: 2013/9/21 0:42
There is little load on the shock. The springs hold the weight of the car.
Posted on: 2013/9/22 19:05
But shock loads are, well they are shock loads which are violent
Posted on: 2013/9/22 23:09
