regulating a fuel pressure regulator
From oregon in the usa
A regulator which seeps excessive fuel pressure at low flow rates should be returned to the seller, but sometimes that is impossible.
Fuel pressure regulators misbehaving that way can still be used by placing a "t" in the regulator output line and another "t" in the fuel pump inlet line. Connect them with a tube and a needle valve. A small fuel backflow through the needle valve bleeds off the excess pressure.
Posted on: 2013/9/27 20:54
Re: regulating a fuel pressure regulator
where does one obtain a needle valve?
Posted on: 2013/9/28 0:35
From Logan, QLD
That achieves nothing.
Posted on: 2013/9/28 1:42
It is a mitigation for "a regulator which seeps excessive fuel pressure at low flow rates". Not a fix for a regulator that is always too high.
Posted on: 2013/9/28 3:13
needle valves of that sort are available in plumbing supply stores for $4.
Posted on: 2013/9/29 0:00
Seepage at low flow rates as reported in Amazon product ratings is a continuing problem for one popular, well-regarded brand of regulator.
Seepage may not be a problem for a carburetor which is fed by an engine driven pump, but it becomes a problem when using an electric pump.
Posted on: 2013/9/29 0:12
Nige suffers from anal seepage too. I wonder if a $4 valve will fix it. Cheaper than teena for men.
Posted on: 2013/9/29 0:48
From Perth WA AUS
No seepage issues on my end.
Posted on: 2013/9/29 12:32
Datsun 1200 2Dr sedan.
