Dyno results
I couldnt believe my luck, on the way to the hard ware shop on Friday and noticed a new garage with the word Dyno on the front.
I stopped to have a look and found that its a guy who's into Drag racing and started this garage to work on Drag cars.
He showed me one with a huge turbo on it and a 3 litre nissan engine which he said gets over 1000 hp....he's running 2.5 bar boost and has a water cooled intercooler...
He has just installed a new Dynojet system he imported from America.
So i asked if i could use it,"no problem just turn up whenever you want, 1000baht a test"
So, here are my results:
A14, std except for K&N filter and tubular header.
RWHP 57.7 @5170 rpm
Max torque 98.39 @ 3080rpm
Can see me getting to know this guy well.....
jpg  Dyno run A14 KN filter headers.jpg (80.12 KB)
16289_562d8e27e1474.jpg 967X616 px
Posted on: 2015/10/26 2:20
Re: Dyno results
$38 aussie roos life is good in thailand :)
Posted on: 2015/10/26 4:41
Re: Dyno results
Quite a regular
From Western Sydney
if only we could have that price here :(
Posted on: 2015/10/26 9:32
1973 Datsun 1200 Sedan (work in progress)
FanaticsCo'*<~~~~
Re: Dyno results
From Las Vegas USA
58 horsepower to the wheels is pretty respectable for a near stock A14. My A12GX with ported head and flatslide carbs made 73 whp and I was stoked about that..
I have not Dynoed the current A15 (flat slides, ported GX head, 37/30 valves, Delta 278 cam 11.5-
1 comp & header) but I'm hoping it will be around the 105-110 who mark.
That's also a good price for a dyno run.
Tom
Posted on: 2015/10/27 4:07
Re: Dyno results
OK , good that it looks ok to people...
Next step, following the A14 tech Wiki instructions, is to look at the ignition and set it to 34 deg Advance..
I'm using 95 octane petrol... i think the head is a H75 would it stand more advance ?
Posted on: 2015/10/27 6:13
Re: Dyno results
From melbourne
Imo you dont want more total advance but you want a faster advance curve and get it all in alot quicker. The stock a12 dizzy get all timing in at around 4000rpm or a bit more which i think is to high
I recurved mine with all in at around 2800rpm and it goes way better.
Know that you actualy have a dyno you can use try increasing total timing and see if you actualy make more power
Would be interesting to see.
Just make sure you dont ping.
Posted on: 2015/10/27 6:55
Re: Dyno results
I'm considering getting one of these, it seems relatively easy to install and gives programmable ignition timing .
http://www.aldonamethyst.co.uk/
According to the Wiki "Recurving the distributor can gain up to 15 HP. Tell your distributor shop to make it all in by 2400 RPM. Then after installation, set the timing to 34 degrees total."
Posted on: 2015/10/27 7:36
Re: Dyno results
From melbourne
I used a recurve kit from a chev v8 and even the lightest spring wasnt light enough youl have to get very light spring to get it under 2800rpm.
For that price you rather get a megasquirt 1 better tunability
Posted on: 2015/10/27 7:43
Re: Dyno results
Took my modified engine to the same dyno today.
This is the same A14 engine but:
A15 crank
77mm Mazda UC pistons
Camtech cams 621 cam
dual valve springs
nodiz crankfired ignition (wasted spark)
C/R 10.5:1 (from memory, need to check that)
38DGAS Weber carb on std manifold
tubular headers 38mm dia
max PS 92.46@5950 rpm (previously 57.7)
max torque 128.38 at 4500 rpm(previously 98.39)
This is using the supplied curve that came with the ignition, i couldnt get the bluetooth connection to work to fiddle with the curve.
Very pleased with the result.
jpg  dyno test feb1 2017 001.jpg (33.02 KB)
16289_58917207dda44.jpg 640X465 px
Posted on: 2017/2/1 5:29
Edited by thaifrog on 2017/2/1 6:02:00
Re: Dyno results
38 dgas is an overlooked carb well done its a beast!
Posted on: 2017/2/1 5:49
