camber adjustment
From durban, south africa
hey guys on my nissan exa how can i set my camber? what mods do i need to do? as i cant adjust the camber
many thanks
nicholas
Posted on: 2005/8/11 14:50
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: camber adjustment
From Burbank, CA
you could do a few things:
camber bolts - work ok, cheap
camber plates - work good, very expensive
there are other ways that you could do it on the cheap, but i'm not going to tell you any of those.
Posted on: 2005/8/11 18:14
|||\ 81 KPB310 /|||
ahh dont be like that!!
what are camber bolts and where do they fit and where do the plates fit, many thanks
nicholas
Posted on: 2005/8/12 7:05
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
On a Nissan Pulsar, the camber is non-adjustable.
Posted on: 2005/8/12 17:00
From Burbank, CA
it wasn't adjustable from the factory, but many years of abuse may have bent your frame or something.
the camber bolts replace the standard bolts that attach the steering nuckle to the strut, they have an off center lobe that allows the camber to be adjusted as much as +/- 4 deg
camber plates replace the strut tops and allow you to adjust the camber a more secure way, for a greater cost.
Posted on: 2005/8/12 21:58
|||\ 81 KPB310 /|||
