problems with carpet fitting
From Brisvegas, oz
it just occured to me that with a larger tunnel the standard 1200 carpet may not be large enough. i know that when you purchase new carpet it gives you a little extra but will it be enough. has anyone had this problem?
Posted on: 2008/9/27 22:34
www.camerasplus.com.au
Re: problems with carpet fitting
From Toowoomba, Qld
I had a similar problem, not in a datsun though.
You can buy marine carpet for a bit cheaper than moulded and then shape it with a heat gun. A little more hard wearing than auto carpet.
Posted on: 2008/9/27 22:52
From Tamworth , NSW
i had to cut about 2 or 3 inches off each side that goes under the scuff trim
Posted on: 2008/9/27 23:36
From Sydney, Australia
Yeah. I bought 1200 auto carpet, but with the tunnel mods for the CA18 gearbox, it needed a couple of wedges taken out. Basically, I need to scrap the whole idea, and take it to a auto trimmer who can do the front section properly with heatguns etc. Too much of a headache for me to deal with.
I also completely melted the carpet under the passenger side when I had to hobble home with an ignition problem when I first put the autronic in... The lesson I learned from that is... If you have ignition problem on one cylinder... identify which cylinder it is, and also disconnect the injector for that cylinder.. A CA14det works good enough to pull a 1200 along.
Posted on: 2008/9/28 0:51
From Armidale N.S.W
Possibly get a front carpet for something like a 180B, Skyline, 120y Auto and cut it down more so on the edges.Trufit don't cut any holes in there molded carpet ( well not in the one i got) so you could mark and cut holes where you need to.
Posted on: 2008/9/28 1:45
73 1200 wagon SOLD
datsun 1600 carpet is close to 1200 it has a bigger tunnel and a little more length and width but is not too hard to fit i say anyways!!
Posted on: 2008/9/28 4:10
Car free
