A12 MAX Overbore???
Hey all,
Just wondered if anyone could tell me what cyl wall thickness was for A12 engine its a mid dizzy one I've seen 76.7 i think it said for some works nissan stuff.... but planning to go to 77.5mm for racing use ... any thoughts???
Posted on: 2008/1/8 7:38
Re: A12 MAX Overbore???
From Bendigo, Victoria, Australia.
yeah, i would say use an A14
Posted on: 2008/1/8 7:40
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
I can't use A14 cos our max is 1340cc
Posted on: 2008/1/8 7:47
From Adelaide, SA
I THINK the biggest you can go with an A12 is 1308cc
Mine is 1298cc (not sure of bore size but could probably calculate it...)
Posted on: 2008/1/8 7:50
Use the A12 crank in the A14 block...
Cant use A14 block cos it was >1340cc at original manufacture
Posted on: 2008/1/8 8:01
1298cc = bore of 76.8mm
1308cc = bore of 77.1mm
so 3.8mm and 4.1mm are fair over bores, considering that noone really overbores a RB more than 2mm
Posted on: 2008/1/8 9:29
Bob Dylan
Ok ... looking like 77mm = 1303.85cc might be safer option for me at this stage
Posted on: 2008/1/8 9:46
Pushing a 1200 or A12 block past 77mm is pushing your luck, but 77mm should be OK in most blocks.
You might want to do the math in relation to the 1974 US model A13 block. This is basically an A14 but with the smaller 73mm bore size & is stamped A13 as the prefix to the engine number. [73mm x 77mm + tall deck block]
US only, .... one year only, so it's not common, but they do exist & might be a solution to your problems.
Posted on: 2008/1/9 8:19
Love your Datsun.
Treat it well.
Cheers guys.
Posted on: 2008/1/11 22:42
