gearboxes for my coupe
From BRISBANE, QLD
guys and girls
i have a ca18det with the standard five speeder in my 1200 coupe. i expect to make around 350 rwhp and have been told the gbox will not handle this. i don't want to convert to an auto, what 5 speeders are able to take this power that will not require me to cut the tunnel?
has anyone tried different boxes? i was thinking the alloy supra five speeder might work...any suggestions?
Posted on: 2008/3/17 9:54
Re: gearboxes for my coupe
From Christchurch NZ
I've been led to believe you can fit the ca bellhousing/front section onto an RB gearbox.
Posted on: 2008/3/18 6:09
Forced Induction!
From Canberra
depends on the RB gearbox I think. From what I've read the RB20DET 5speed is basically the same box as the ca18det/sr20det used. The rb25det box is bigger, but the bellhousing may not (probably wont) bolt up.
Posted on: 2008/3/18 6:12
From Okinawa Japan
Yep rb25det gearbox is bigger and will not bolt up to CA/SR. 350whp is doable on a CA18det gearbox as long as you don't try to run a twinplate or equivalently harsh clutch.
Posted on: 2008/3/18 6:26
From BRISBANE, QLD
thats the problem i guess. i want a car that can do a bit of everything. daily duties, test and tunes and the odd curcuit bash. it has a single plate organic clutch and a strong pressure plate so shouldn't be to harsh.
i had toyed (pardon the pun) with the idea of a supra box too but that seems to be an expensive excercise, bellhousing/new tail shaft.
anyone tried this route??
Posted on: 2008/3/19 0:20
From Canberra
which supra box are you talking about? The W55/57/58 or the R154? The R154 (from 1jzgte I believe) is massive but a lot of the toyota guys reckon they are completely overrated. I'm not sure how much stronger a W5X (from lots of older toyota 4 and 6cyl motors) would be compared to a CA/SR box.
I reckon go though some magazines or something and see what boxes the big power CA18s are running.
Posted on: 2008/3/19 1:46
From BRISBANE, QLD
w58 is the box i was told might work....most people i have seen with this set up or bigger have gone auto....call me what ever you like but i like shifting my self...
Posted on: 2008/3/19 3:03
Back after a long absence and looking to build a beast starting with a 1974 1200 sedan
