1000 5 speed reverse switch
From Fremantle, West Australia
When fitting a 60 series 5 speed into a 1000, the reverse switch clashes with the original anchor point for the g/box support bracket.
Has anyone fitted a 5 speed to their thou AND kept the reverse switch operational?
Do the original anchor points stay or go?
Thanks
Posted on: 2009/2/16 13:17
Re: 1000 5 speed reverse switch
From Coondle, WA Australia
Umm for all intents and purposes, you have to remove the reverse switch to make it an easyish job.
Sounds like the only option is to custom make a bracket to bolt everything up.
Hmmm someone accross the road might be able to help
Posted on: 2009/2/16 14:40
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
OK ,so there are no 1000 reverse switch Gurus out there!
I have a B10 wreck and a FS5W60A and FS5W60L (dogleg) 5 speeds and set about fitting them to see what mods were required and which was the easiest fit.
The 2 boxes both fit, just!
With the standard pattern 60 series box, the reverse switch totally clashes with the factory right tranny mount. So there are 2 choices---plug the reverese switch and fit a manual switch in the cabin or carve the original mount off and keep the switch. Even then, the rev switch wires have about zero clearance so cutting a 35mm hole in the tunnel and covering with a rubber gromett would be wise.
The dogleg box reverse switch is about 50mm higher than the standard pattern box.
This means you could get away with NOT carving the original mount off but the switch wants to protrude about 15mm into the tunnel. You have no choice but to cut a hole in the tunnel if you want to keep the switch.
With either box a custom tranny mount is required
Conclusion: to keep it legal, I will use the standard pattern box and carve off the original mounts.
But before I cut a hole in the tunnel of a decent car, I am going to see if I can find a reverse switch which is shorter than the original unit.
Posted on: 2009/2/28 11:36
From 6065
i did a switch on my wag for reverse lights and just mounted it under the dash. its a quik easy solution.
Posted on: 2009/2/28 12:05
Yes, there are lots of 5-speed reverse switch gurus here. You too have now achieved full knowledge of the problem.
Posted on: 2009/2/28 18:16
