Steering Box Ratios
From Newscastle, Australia
Hi just wondering if there was a closer ratio steering box available for the 1200. Teretonga tells me that the B310 steering box has a better ratio for track work...(ie less turns lock to lock) anyone know??
Posted on: 2003/11/24 12:51
Re: Steering Box Ratios
From Collingwood. Victoria. Aus.
That is correct... (ie less turns lock to lock ).
I don't know about actual turning circle, I am off the road and can't compare the 2.
Posted on: 2003/11/24 21:24
Never ever grow up
From Melbourne, Australia
but the steering column and stuff is diffrent,
it would be good though for the ratio obviously but also it should be easy to put the wiper controls and stuff on the steering column as i think the sunny has then there
Posted on: 2003/11/25 9:15
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From T'ville
i dont think he wants to change the colum just the box
Posted on: 2003/11/25 11:52
Not too shy to talk
From Sydney, Australia
On my rally coupe I have shorter steering arms on the bottom of the struts to make a quicker turn. I think it's just more than two turns lock to lock. Means I don't need a massive hand-over-hand effort everytime i go sideways usually just needs a flick off the wheel to correct.
Sorry not sure what they're off but the struts are off a Gazelle so maybe thats it.
Posted on: 2003/11/26 3:59
From newcastle, NSW
does anyone know if the steering can be modified so that full lock is only 1/2 or 3/4 turn, a fella i went to school with had a gallant like that, i dont know how, but sure as s#@t it worked.
Posted on: 2003/11/26 8:16
my point was u could not just change the box you would have to modify the column to adapt to it
the galant would have a rack and pinion steering system and also a lot of "works" parts floating round like quick racks, so no you wont get that on a 1200 easy
Posted on: 2003/11/26 8:58
1200 Coupe Rallycar
From newcastle, NSW
DAMN!!!!!!!!!!!!!!!!
Posted on: 2003/11/26 11:10
