Tyres
From Chipping norton sydney
Hi everyone just wondering wat size tyres there running on there datsun 1200 ute with big power as I can't get anythink bigger than a 195 under it is there somthink I'm not doin right cause I have no traction wat so eva .
I have checked to see if the diff is center that's all gud i just dono where to go from there other than a 4 link n big tubs any help would be great cheers
Posted on: 2012/2/12 11:21
Re: Tyres
From West syd
Iv had 205 on rear but need to lip the gaurds
Posted on: 2012/2/12 11:39
Re: Tyres
From Las Vegas USA
I'll assume this is in a straight line.
Questions,
Define big power, if it has 300 then um yeah it's going to light the tires.
What shocks? dampers? You could increase the rebound in the rear to keep it squat.
What compound type of tires?
Tire pressures??
Ride height? You could raise the front or lower the back slightly.
Also what rear gear, and also what gear or gears is traction a problem?
Tom
Posted on: 2012/2/13 2:14
Re: Tyres
From Melbourne, Australia
two options...
1. put the 500kg pay load in the back that the ute springs are designed for
2. put coupe/sedan springs in there that arn't designed for that
you probably have not put new shocks in either.... that is gonna make a massive difference too
Posted on: 2012/2/13 5:24
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Tyres
It's got brand new Koni adjustable shocks
Posted on: 2012/2/13 7:57
Re: Tyres
cool, so its just the springs then
you got a big turbo giving a big power whack at once or reasonably smooth power delivery?
you trying to drive fast or do burnouts? you got open or lsd or locked diff?
the more you tell us the more we can help
there are your tyres hitting? what diff? what wheels? blah blah blah
Posted on: 2012/2/13 8:26
1200 Coupe Rallycar
Re: Tyres
This is no 'trade secret' but there are good and bad tyres, each have combinations of longevity vs grip, vs sidewall ridgidity/compliance - and basically each tyre is made to emphasize whatever they think is most important for their users. So basically if you look at a more expensive, grippier tyre (that will wear out a lot quicker) you'll get a better result.
Driving style is a HUGE thing on something like a ute, which has less weight over teh rears (in general). If you do add any weight, add it right in the tailgate region, so it has more 'leverage' to create more downforce than if it was just over the axle centreline. But note that doing that also gives it more 'leverage' for hte rear to start to break loose during a hard corner when you accelerate mid corner or on corner exit. But on driving style specifically, you need to (at the expense of clutch life) slip the clutch off the line _ a fair bit _ as power goes up, so that there's rearward weight transfer (and the whole body doesn't have to actually tilt rearward a lot - weight transfer can happen without massive suspension movement). So that certainly helps.
The next thing is suspension setup - is there any chance it is lowered at the rear (maybe the front too, but the rear is the big deal for this one) ?? If it is lowered, two things can be big time bad news there. Firstly, if it uses lowering blocks, they space the axles away from the springs, and give them more 'leverage' and it's a lot easier to wind up the leaf springs in a layed down S shape, and that will lead to axle tramp, and a loss of grip..
And on top of that, if it is lowered by lwoering blocks, or reset springs (either way) and it has been lowered to the point that the axle centreline is level or even higher than the front spring eye bolt, then that is very bad for launch/traction.
THere's a little bit more to it than that but in very basic terms, if the axle centreline is lower than the front spring eye bolt, as the wheels push forward, the front of the leaf angles upward, and so it pushes forward AND tries to raise the car up (pivoting on the front spring eye bolt). It won't 'actually' raise the car up, it will just try to. Since it has rearward weight transfer at the same time, the car resists being raised, so what instead happens is it tranfers the force, and actually pushes the rear tyres down onto the road surface, increasing the downforce, and therefore the grip..
Not surprisingly, if it has been lowered far enough that the axle is level with or higher than the front eye bolt, it'll try and push the other way, and lower the car, or as before instead of lowering it as such, it'll REDUCE the amount of downforce on the rear tyres. And that might be exactly what is happening.
The next 'related' issue is the springs again. Over the years, due to the engine rotating/powering in one direction, it always has some twisting force acting on the diff/housing at full power, esp in the lower gears. This then raises the right rear under each hyard launch. Which is why non lsd diffs tend to always spin the right rear when you launch hard.
OK, so over the years that right rear leaf sees more stress/forces and will sag a little more than the left rear. So that means the right rear tyre is always having less downforce, so it won't grip off the line. And even with an lsd, you still have inconsistent grip left vs right and overall traction is not optimised.
You could put in new springs, hey no drama. BUT even with new springs with even heights, well that right rear is still going to lift on a hard launch. One of the tricks (and I haven't done it specifically on a 1200, but on plenty of other cars) is to swap the left and right rear springs from side to side. That way now the left rear has a little less downforce than the right when stationary. BUT when you launch hard, it lifts the right rear, and since the right was pushed down a little harder than the left to begin with, well when it lifts it, it ends up back to (or very close to) 'even stevens' left to right rear downforce, and launch potential is optimal.
With regard to the axle vs front leaf eye bolt heights, there's not any great way around it, you might need to raise the rear (though I admit I don't currently know what the rear is currently setup like, so I'm trying to cover all things it _might_ be). The other way would be to raise the front eye bolt location. That's not really doable easily on a datto, you'd have to move the springs inboard of the chassis rail section, so they could be located higher (and you'd oo inboard, not outboard, since this would also allow for larger rear wheel sizes.
If the heights of said pieces are ok, but it's still showing axle tramp, then traction bars are the go. There's a few articles on how to make and install them in general on the net, and there's also either a thread in the archives here, or on the datsun 1200 tech wiki pages.
Posted on: 2012/2/13 9:53
John McKenzie
Re: Tyres
I'm going to look at this axle height vs front eye bolt height. You mean the bolt holding the front leaves to the chasis correct?
Posted on: 2012/2/13 10:07
Re: Tyres
your a beast jmac! What he said
Posted on: 2012/2/13 10:08
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
Re: Tyres
unbelievable that you would sit there and write a post covering so many bases when the original poster hasn't bothered to post much detail about the setup at all... a very patient man you must be....I love your passion for cars!
Posted on: 2012/2/13 10:15
1200 Coupe Rallycar
