Ca parts question
From Goulburn NSW
Hi guys can anyone tell me what the name off this part is and whats its purpose.It connects to the right cam gear on the outside off the cam cover so im guessing it has something to do with the cams,also it has a mitsubishi symbol in the centre on the black part.
jpg  001.JPG (108.03 KB)
14333_512869d81d7d4.jpg 640X480 px
Posted on: 2013/2/23 7:04
Re: Ca parts question
From Chipping norton sydney
Its called a CAS sensor normal name crank angle sensor
Posted on: 2013/2/23 7:12
From Canberra
Probably the most important sensor for an EFI car.
As above, provides the ECU with Crank and Cam position.
Posted on: 2013/2/23 7:19
From Goulburn NSW
Hi guys is this the crank angle sensor or the camshaft angle sensor?
Posted on: 2013/2/25 9:54
From Brisbane
cam angle sensor. lots of different names for different cars. when you upgrade you cas you use Hall sensors which can be mounted on the crank or cam
Posted on: 2013/2/25 10:02
From Goulburn NSW
So the one to buy will be the same as the pic.
Posted on: 2013/2/25 10:06
From Brisbane
If the shaft still spins just clean it up. Cost for a new one is pretty high if you don't know where to look
Posted on: 2013/2/25 10:28
