« 1 2 3 (4) 5 6 7 »
Re: 1200 coupe project
From central qld
So chopped some more datto away
jpg  20200320_164912_resize_80_compress92.jpg (128.10 KB)
15654_5e7c7b2a41a65.jpg 806X604 px
Posted on: 2020/3/26 9:51
From central qld
Recessed firewall 60mm used the original piece that cut out only as to keep the look stock as I can. Had a old tunnel I made for a ke20 I cut out so chopped it up and made it fit, wasn't how I wanted to make this one but turned out ok so happy with it.
jpg  20200322_173236_resize_60_compress13.jpg (121.50 KB)
15654_5e7c7f8d7e4e9.jpg 806X604 px
jpg  20200324_144458_resize_5_compress52.jpg (152.38 KB)
15654_5e7c7fb2d460e.jpg 806X604 px
jpg  20200326_161100_resize_75_compress26.jpg (139.15 KB)
15654_5e7c7fe633922.jpg 806X604 px
Posted on: 2020/3/26 10:15
From central qld
Fitted engine box and sits nice. This is wherw I'm up to now so need to make intake manifold make intercooler piping.
jpg  20200326_174605_resize_66_compress15.jpg (115.96 KB)
15654_5e7c875e7f742.jpg 806X604 px
jpg  20200326_174619_resize_46_compress53.jpg (106.09 KB)
15654_5e7c877437606.jpg 806X604 px
jpg  20200326_174601_resize_75_compress79.jpg (107.69 KB)
15654_5e7c87a09ab56.jpg 806X604 px
Posted on: 2020/3/26 10:51
From central qld
I want a plazmaman plenum but can afford one so made a intake manifold today, it's rough but a quick job and a 68mm ford mustang $50 ebay special tb . Havnt used the tig in 5 years but was good to rip it out.
jpg  20200329_161525_compress37.jpg (176.87 KB)
15654_5e8074ef492fe.jpg 2016X1512 px
Posted on: 2020/3/29 11:17
Great to see this build gaining momentum again.
Where did you buy that intercooler/radiator setup from?
Love your intake manifold to. Who needs Plazmaman Not you!
Posted on: 2020/3/29 14:56
From central qld
Hi cadet1200 i bought it from a guy. It was a custom ARE cooling setup made like 20years ago and if you Google ARE dataun 1200 ca18det something like that and images you might find a pic or go to there website and will find some old pics. I wish i had a plazmaman manifold as they neat as.
I've been so busy with new house, moving setting up shed pool etc etc. No money or time for this project but back to it now.
Posted on: 2020/3/30 5:19
Plazmaman? I prefer the purpose build look than
lady like finishes. If you worry about your welds
at last resort you can crinkle finish it to match
your rocker cover. All looks great from here.
Posted on: 2020/3/31 4:43
From central qld
Thanks D I probably will paint it now and wrinkle finish is not a bad option I never done it before but I'm sure I can master it
Posted on: 2020/3/31 9:28
From central qld
had to cut off the exhaust manifold turbo flange and rotate it as turbo hit the strut tower due to engine being back alot. Done the intercooler pipe to engine but only got 3inch silicon joiners so have to order couple 2.5in ones as turbo compressor is 2.5 anyway.
jpg  20200401_151520_compress32.jpg (196.40 KB)
15654_5e842b0ab41ab.jpg 2016X1512 px
Posted on: 2020/4/1 6:52
From Melbourne, Australia
wow... not mucking around. looks great!
Posted on: 2020/4/3 6:14
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
« 1 2 3 (4) 5 6 7 »
