A-14 VS 1200GX VALVE SPRINGS
From durban, south africa
ok i went to nissan and they rekon the gx has 2 valve springs, fine, are the outer springs the same on the gx and the 1400? and can i use the inner spring on the 1400 now without any modifications??? In other words can i use the standard outer 1400 spring with the gx inner spring?
Posted on: 2004/10/27 13:57
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: A-14 VS 1200GX VALVE SPRINGS
From Christchurch NZ
Buy all new ones. Valve springs do wear out. don't be cheap.
Posted on: 2004/10/28 10:22
Forced Induction!
