200B rotors
From melbourne
Hi All
Does anyone in Tassie have any 200B rotors for sale or know where I can get some?
Posted on: 2007/1/16 21:58
Re: 200B rotors
From Sydney , NSW
What happened to the landcruiser upgrade????
Cheers
Posted on: 2007/1/17 9:31
All torque, no traction
A division of "My mate's ....." engineering
Re: 200B rotors
From Canberra
you can still do a landcruiser upgrade with 200B rotors right? just not vented
Posted on: 2007/1/17 9:32
Re: 200B rotors
From Geelong, Vic
you can, but would have to use old pad backing plates to space the pads out to reach the disc
i have some crossdrilled 200b rotors that were machined about a month ago
but im in victoria
Posted on: 2007/1/17 9:57
Re: 200B rotors
From melbourne
Dont worry, I am still doing the landcruiser upgrade - we are trying a few other things right now just to see.
I am currently running what we noww know are 10" 200B solid rotors - would you believe that the landcruiser calipers literally bolted into the same holes that the 200B calipers were in!!!!
All we need to do is space adequately & we have 4 pots on solid discs! I know its not perfect bu with time & money being s so stretched its a little hard.
I plan to use the 10" S13 vented very soon.
Posted on: 2007/1/17 21:09
Re: 200B rotors
From Canberra
wouldnt it just be easier to get 4pot calipers off a landcruiser that also had solid rotors???? Or are the cruiser solid rotors still thicker than 200B solid rotors??
Posted on: 2007/1/17 22:28
Re: 200B rotors
From melbourne
in theory yes but the hubs etc are no where near even similar form the landie.
the pacer required is only a bit small piece of steel - nothing major.
I thought for the simple effort of a spacer, to be able to bolt 4 pots straight on & drive away is incredibly convenient.
Posted on: 2007/1/17 23:20
Re: 200B rotors
From Geelong, Vic
i advise you to use camry discs like i did rather than the s13 rotors when you decide to go to vented
just have to buy them undrilled so the disc mounting face doesnt end up looking like swiss cheese
Posted on: 2007/1/18 0:51
Re: 200B rotors
From melbourne
Oh OK - they are obviously very similar to the s13's.
what year & model camry should I be looking for?
I think Ill go through DBA.
Posted on: 2007/1/18 1:03
Re: 200B rotors
From Geelong, Vic
yeah they are slightly bigger than s13 ones
they are from an sv20 sv21 or sv22 camry
year is from 87-92
they are a 255x22mm disc
DBA number is 730
might have to machine the disc down to 20 or 21mm thickness so it fit in with new pads
Posted on: 2007/1/18 1:24
