how do i make my head flow better
Not too shy to talk
From k faffs OR
now can i make my a14 head flow as well as a gx head because i cant find one
Posted on: 2003/2/6 21:59
cant wait to race
Re: how do i make my head flow better
From Melbourne, Australia
is it round or oval inlet port, the one you have i mean, a-14's came with both
Posted on: 2003/2/7 8:17
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney, Australia
kick it! LOL
Posted on: 2003/2/7 8:26
Not too shy to talk
From k faffs OR
hay 1200rallycar. Thay look to be round. There is
alot of space between them. And can i safly drill and tap it for more studs if i seal the threds
Posted on: 2003/2/7 19:00
cant wait to race
From Toowoomba, australia
does anybody know if it is possible to get a stud kit for the head? have studs instead of bolts.
thanx DAVE
Posted on: 2003/2/8 2:20
why go up and down when you can go round and round
first thing i would be doing would be getting an oval port head off an a-14 for it, it will be a great improvemnt in flow without modification, i think, not sure but it may even have larger valves in it too
as for the studs ive never done anything like that so i couldnt really tell ya
im, thinking your reply will read "a-14's are too rare to find an oval port head" or something to that effect but i really think its the way to go
Posted on: 2003/2/8 3:13
1200 Coupe Rallycar
From Christchurch New Zealand
no Not an A14 head get an A15 head as they have a lot more meat on the gasket face so you cane get the head planed for high compression without getting hotspots
Posted on: 2003/2/8 7:06
"If your not living on the edge your taking up too much space" Rod Millen
oval port heads are the common A14 head in the US.
jimmy, the round port heads have perfectly round ports. If you take the intake manifold off it will be easy to tell.
Posted on: 2003/2/8 7:08
Not too shy to talk
From k faffs OR
the ports are round is that good or bad
Posted on: 2003/2/8 17:47
cant wait to race
From sydney australia
arp make a stud kit for both a12's & a14/15's.haven't found anyone in aus with one in stock yet,but check out www.wholesaleperformance.com.au for part numbers.they're in brisbane,they're an importer,& the site has a link to arp.
Posted on: 2003/2/8 22:23
