Re: a12 making crazy power @rebels dyno comp in QLD
From Brisbane, Australia
having messed around with a couple of turbo A series engines, I'm very impressed that a stock A12 piston managed to survive even one dyno run at 18psi!
Posted on: 2007/3/11 9:01
From Christ Church, Barbados
Thats pretty insane. Test it on another dyno and let us know the results though, because that is a lot of power for a 1200. I didn't even think the head could deliver enough air to make that sort of power. If that hp figure is accurate than I would really love to know what parts and work went into that engine cuz...well...wow!
Posted on: 2007/3/11 9:17
That's more power than lots of the CA18 conversions are making. Does this make this conversion obsolete? I don't think so, how many millions of gearboxes will it go through? How much midrange torque will it have? how many bottom ends will he go through?
It really has got everyone thinking about that tired old 1200 in their car though hasn't it???
Posted on: 2007/3/11 10:30
From Brissy
it was done in third gear.. 4th would be better due to the 1:1 ratio but it would not go in after the tuning done on friday....
it was a dyno comp!!!
with two new dyno dynamics dynos...
i saw it make 195hp on the dyno last year with a a14 and a blow through carby turbo setup... it then cracked a piston
Posted on: 2007/3/11 10:31
From Wagga Wagga
yo, topgear, what type of air filter is that (never seen 1 like that before)
Posted on: 2007/3/11 10:33
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
From Wagga Wagga
juat a Q is $800 good for a 1200 ute with an a15?
Posted on: 2007/3/11 10:35
A15 Engine
5 Speed Sunny
H165 Diff
From Vic Bendigo
if it was at a dyno comp evan if it was off the other cars would have got the same reading so really it dosnt change a thing its still beaten the ca's
Posted on: 2007/3/11 10:41
Was some cheap air fliter I brought from the local "Supercheap"....?? Nothing specail, probably just an after market SU style carbie filter...
Posted on: 2007/3/11 22:11
ddgonzal wrote:
. The only way to make more is to pressurize the engine (18 lbs boost is a lot, over two atmospheres). .
Hows 18psi more than 2 Bar?
Posted on: 2007/3/11 22:33
Sorry, I didn't mean 2 bar boost, I meant the cylinders were under 2 bar pressure. 0 boost is atmospheric pressure (14.7 lbs). Then add another 18lbs of boost.
Posted on: 2007/3/12 1:47
« 1 2 3 (4) 5 6 7 »
