32/36 webber
From Warwick, QLD
can a 32/36 webber that is on a standard A12 head fit onto a GX head??? Or is a new manifold needed, if so how much or does someone have one up for sale??? cheers
damo
Posted on: 2003/3/17 13:36
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: 32/36 webber
Nope, a 32/36 is a downdraught, whereas the GX manifold is for twin sidedraughts.
See the Tech Section article Weber 32/36 Carburetor
Posted on: 2003/3/17 18:45
Re: 32/36 webber
should the Gx manifold, just snap staright in to the a12?
Posted on: 2003/3/18 3:16
Re: 32/36 webber
Now you'll be wanting info on the GX parts. See the Engine Tech Section, there is an article on the A12GX engine, including pics.
The bolt pattern of the GX manifold is different from a regular A12 (it's more like an A14, but slightly different from even that).
Posted on: 2003/3/18 5:20
Re: 32/36 webber
From Launceston,Tasmania,Aus
Is a 32/36 webber to much for a standard A12???
I have one on my 1600 that i was thinking of putting on my new 1200 ute...
Will the adapter plate fit the A12 manifold or are they different to the L series???
Posted on: 2003/3/18 6:44
Re: 32/36 webber
From Warwick, QLD
can you get a manifold for a 32/36 webber to fit a GX head???
cheers
damo
Posted on: 2003/3/18 6:54
Team NEW SKOOL
Re: 32/36 webber
From Brisbane, Australia
I believe the real GX heads (there are many A14 heads out there being called GX heads) have two studs for inlet manifold. so if you got an A14/15 oval port manifold and drilled it to suit the two stud GX head, or drill and tap the head for the extra studs the A14/15 manifolds use. I can't see why that would be a problem
don't you have the GX manifold and Hitachi SU carbs?
Posted on: 2003/3/18 7:16
Re: 32/36 webber
From Warwick, QLD
yeah harry, I do have the GX manifold and SU's but this is info for a friend :)
thanks
Damo
Posted on: 2003/3/18 7:24
Team NEW SKOOL
Re: 32/36 webber
The 32/36 is not "too big" for an A12 engine. If you want smooth response and the best fuel economy, stick with the stock Hitachi, but if you want to rev the engine up high, the 32/36 is a good carb.
The L-series carb has a different bolt pattern, so the carb (or the adapter) won't fit on the A-series manifold.
Can you get a 32/36 manifold to fit a GX head? Probably not new ... usually an adapter is used with 32/36 carbs. Plus, all the GX manifolds I've seen are dual side-drafts. If you have a GX head, best to use the GX manifold and its twin carbs.
Posted on: 2003/3/18 7:38
Re: 32/36 webber
From Tassie, Australia
I originally got the GX head with the twin SU carbs. When I bought the rally car I got a manifold for twin Dellorto/Weber's thrown in, and it sits nice and snug on the GX head. I am gonna turf the twin SU's and find a set of Dellorto's/Weber's (twins) to suit. I reckon they will be about 40's.
Posted on: 2003/3/18 9:11
