Down Port Heads
From New Zealand
would anyone have any ideas on downporting a race 1400 GX to a race 1298cc engine. if its wort while and how?
Posted on: 2007/7/3 1:42
Re: Down Port Heads
Downporting? I think they call it "de-stroking".
The A14 is a lot heavier than an A13 works racing engine. Most racers start with A12 and bore it out to make 1300 cc class engine -- some blocks can do it. The north american A12A block is even better and can always be bored to that size. Both are lighter than A14.
Posted on: 2007/7/3 4:51
Re: Down Port Heads
From Christchurch NZ
Whereabouts in NZ are you?
Posted on: 2007/7/3 5:06
Forced Induction!
Re: Down Port Heads
From Wellington New Zealand
Ring Tony at Marsh Motorsport in Auckland, or Brendon at CSL in Palmerston North, and they will explain whats involved and how much it will cost. Tony will probably suggest a more traditional style of porting that works just as well.
Posted on: 2007/7/3 7:17
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
Re: Down Port Heads
From Townsville, Qld
why not stick some massivley over sized sleves in the bores to bring them back down to the old A12 specs? suppose you would have to changew the rods and stuff aswell to accomodate the pistons so probly not
Posted on: 2007/7/3 9:37
Re: Down Port Heads
From New Zealand
I am in Auckland the car is ChCh where it has always raced. Black 1200 coupe
Posted on: 2007/7/4 0:55
Re: Down Port Heads
From New Zealand
Thanks. I dont think to many people have heard of a down ported head. Auckland, Car is in Chch where it has always been raced. black 1200 coupe
Posted on: 2007/7/4 0:57
Re: Down Port Heads
From New Zealand
Cheers for reply, but a downported head is when you block the ports up with alloy weld and then bore down on a angle through the top of the head(sleaved) about a 20 degree or so angle. apparently 30Bhp right there.
Posted on: 2007/7/4 1:00
Re: Down Port Heads
From sydney
So thats what downporting is, glad you cleared that up, your first post below,read to me like you wanted to decrease the engines capacity from 1400cc to 1298cc.
Posted on: 2007/7/4 1:56
Re: Down Port Heads
From Brisbane
i have seen a 1600 Kent engine (escort) that had down ports, i guy in england was doing them, can't remember his name, he released a few books about hi-po 4cyl ford motors etc
Posted on: 2007/7/4 4:38
