Weight differences, L18t z18t CA18det
From Geelong, Vic
just been wondering for a while what option would be best weight wise after reading something that said that the CA18det weighed less than a z18t
and im guessing an L18t would weigh about the same as the z18
so if anyone knew the weights of these engines with or without accesories or knew any sites that might help it would be much appriciated, even an educated guess would be a start
Posted on: 2007/11/1 5:39
Re: Weight differences, L18t z18t CA18det
From Melbourne,Australia
They would all have to be pretty similar mate all iorn block 1.8's with alloy heads maybe the ca is a bit heavier due to an extra cam? If your planing a conversion go a z so i can know of 1 more on melbourne roads
Posted on: 2007/11/1 7:54
From SE Melbourne
CA18DET = 128kg
I thought I had Z18ET weight....but don't.
I'll dig around.
A15 = 93kg by comparison
FJ20ET = 166kg
L20B = 137kg
SR20DET = 149kg
Hope that get's you started.
Posted on: 2007/11/2 1:14
Mildman, Datsunless
From Geelong, Vic
so shave a half inch of deck off the L20b block and you would be close to CA
are those weights short blocks or with manifolds and such?
trb012, what is the difference block and bottom end wise between the L series and the z18t? are the Zs any stronger?
Posted on: 2007/11/2 1:22
From SE Melbourne
Yeah I'm pretty sure that's short block (including manifolds) as the CA18DE = 113kg.
Posted on: 2007/11/2 1:38
Mildman, Datsunless
From adelaide
Nope zs basically same bottom end as l with zed pistons apparantelly having more of a dish to drop cr. Z pistons no longer avaliable everyone just uses l18 no probs. What sort of l setup you planning i have had tonns of boosted l experience if ya want info or just buy my setup haha. L heads flow heaps more than z heads too and easy parts
Posted on: 2007/11/2 5:11
1200 restoration project moving slower than it actually is
Quite a regular
From TOWNSVILLE QLD
any one got the weight of a sr20 de?
Posted on: 2007/11/2 8:16
From SE Melbourne
I've got the sheet of weights at work - but from memory the SR20DE is about 15-20kg lighter than the DET....similar to the difference between the CA18DET & DE
Now if someone wanted to start a wiki page about nissan engine weights....this would be a good start
Posted on: 2007/11/2 12:38
Mildman, Datsunless
From Gold Coast
yeh go the Z.
Posted on: 2007/11/3 8:31
z18-microtech-frontmount-t3/t4
-external gate-screamer pipe-
From Geelong, Vic
thats what i wanted to hear, although the factory efi on the Z would be cool i think i can live without it
dont really have the money to spend on ready made setups....and making one wont cost me that much
Posted on: 2007/11/3 8:47
