Re: NEW Alternator for and "A" Series
Quite a regular
From Redland Bay Brisbane QLD AUSTRALIA
No the alternator light does not come on, and it was a new wiring loom about 10 yeras ago, but I'bve only travelled about 20,000klm or 8,000 miles so it may not be the wiring, but I will check and I will check out the regulator as well, thanks guys for all the tips!
Oli
Posted on: 2008/1/27 9:28
1960 A15 Nissan Powered Morris Minor 2 Door &
1950 Sidevalve 918cc Powered Morris Minor Tourer
From Castro Valley,CA USA
I've had the brushes in the alternator wear out twice.
The charge light came on intermittently when this happened.
Posted on: 2008/1/27 10:21
From Sydney
I run a Sigma one on mine... not sure of the exact details, but it's higher output than the 1200 one, and a bolt on fit
What model sigma? Or are they all the same?
Posted on: 2008/1/28 13:02
i run an internaly regulated xf falcon alternator, 1 hour job to cut down bracket with a hack saw or 2 mins with an angle grinder to make it fit, pulley is at the right spot to, in line with the other 2
Posted on: 2008/1/28 21:22
From sydney australia
i used the alternator off a Z24 from a navara, it's internally regulated & has a larger pulley on it than the standard one. This slowed the alternator down, which was important as it was a race engine.this meant the alternator did not burn out. Went straight onto the later a series alternator casting & the alternator arm lined up too. No grinders needed.
Posted on: 2008/1/30 10:16
From South Africa, Bloemfontein
I am also looking at replacing my altenator as it is a LUCAS one.Not so much amps that it puts out.
All you guys are talking about weird cars that we don't get here in South Africa.
Except for Quote:
written by b310gx. Is this a Nissan car?
Posted on: 2008/1/30 12:07
1977 Datsun 1200GX
From Sydney
Nissan Navara 4/2 door ute.
Posted on: 2008/1/30 12:54
Hey guys im replacing my Lucas alt with an XF falcon alt. I have 3 cables, one that goes to the battery which i have no problem with.
Can someone tell me which terminal the light goes on on the xf alternator?
Also i had stuff running off the Acc + terminal on the lucas, what terminal would that go on on the XF alt?
Posted on: 2008/1/31 8:05
The Navara is 1 Tonne utility, it's model designation is D21, was available between 1986 until about 1992, when it was replaced by a D22. I'm sure that if you could find a Nissan commercial with any of the Z engines (Z20-Z24), either a utility or a van, either a vanette or an urvan, you could probably find the alternator would be usable.
Posted on: 2008/1/31 22:01
Posted on: 2008/2/1 2:56
« 1 (2) 3 »
