help req for sc14 setup METH/ WATER INJECT??
hi people i have just bought this off a member off this site, im needing to no how to set it up but having troubble with figureing it out. need to no how much boost i can run draw through, also how to deliver fule and oil and vac/boost to the manafold. thinks thats it please help
Posted on: 2008/10/7 10:02
Car free
Re: help req for sc14 supercharger setup
From campbelltown (sydney) australia
u can only run wateva boost the pulleys will let you run, if its draw through then its an easy setup as the venturi governs fuel flow, if its going to be blow through you will need a malpassi carby/turbo fuel reg i know thanks to phunkdoktaspok that these work and from personal exp. what do u mean by deliver fuel oil and vac boost? fuel with a fuel pump, oil from oil pump, or the supercharger has its own reservoir. the vac and boost will just come from a vacuum line.... hope this helps, its going to be alot of work bit less as long as the s/c mount is good enough, turbo is much easier with more scope for performance than a toyota supercharger would love to get on running and see how it goes tho ...
Posted on: 2008/10/7 11:10
* caution, sunglasses must be worn to view my ca18det *
thanks for the help, there are 2 whires in the sc14 and am not sure wat they are 4.
this setup has already been on an 15 b4. so all the mounts should be good its still togeather. its gonna be a draw through setup so stock or 4psi pump should be enough?? also there is a line that comes out of the boost side that has a treed not sure wat it is and there is on in the manafold think the one on the manafold is for boost gauge and the one on the boost side of charger could b where he had meth inj.
Posted on: 2008/10/7 11:24
Car free
they re for the clutch to make it come on or are they extra wires than those two.
Posted on: 2008/10/7 11:28
no just the two. do they need an oil feed?? dont no much bout them.
Posted on: 2008/10/7 11:32
Car free
i also need to no if i ned to hook these up?? if so where 2??
Posted on: 2008/10/7 11:42
Car free
From Canberra
they may be for ABV? I would Tee them all together and hope for the best
Posted on: 2008/10/7 11:46
if i tee these up where do i have to run them to?? also how do i wire it up??
any ideas?
Posted on: 2008/10/7 11:55
Car free
From hastings,vic
need to supply the wires with 12v then clutch will ingage boooooost
tommo
Posted on: 2008/10/7 12:18
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
ok. does anyone now where i can find some pics on how to set it up??
ive read a fair bit on it and still am un sure how to fit!! me dumb need pics or wire dig and need to find out how oil is fed to the charger
Posted on: 2008/10/7 12:30
Car free
(1) 2 3 4 5 »
