CA18DET Throttle cable in 1200 coupe
From SE Melbourne
Interested in what people have done with their throttle cables - I've got a throttle cable in my box of parts that looks a lot like the on in this photo.
http://datsun1200.com/modules/myalbum/photo.php?lid=18984
It fits fine on the CA side (so I think it's an S13 cable), it doesn't get through the hole in the firewall, (which is cool as I have a drill) - but it doesn't look like it fits to well on the std 1200 accel pedal.
Just interested in what others of done, as this cable I have looks like it could be a winner...
Posted on: 2009/3/1 0:07
Mildman, Datsunless
Re: CA18DET Throttle cable in 1200 coupe
From Geelong, Vic
i just shortened the stock 1200 cable and put an adjustable end on it like what the S13 cable has, when i say i did it i mean i told dad to do it...and it got done
Posted on: 2009/3/1 0:11
From Melbourne, Australia
you STILL building that thing
maddat sells one
otherwise pigdog just posted photos of how he modified the pedal to suit CA one
edit - posted same time so there ya go
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Geelong, Vic
i did what now?
i think your thinkin of my clutch setup, accelorator is still stock 1200 stuff
Posted on: 2009/3/1 0:13
From SE Melbourne
Man it sucks I'm the only one in my family into cars, or any sort of fabrication work.
I don't even have a spare 1200 throttle cable to try it out with! - but I'll keep it mind if I get desperate - might even have to talk to you and your Dad about an arrangement....
This cable I've got looks OK as well - it's just getting the in cabin side sorted.
Look forward to hearing others experiences.
Posted on: 2009/3/1 0:14
Mildman, Datsunless
From Geelong, Vic
could knock another one up easy enough if i've got another stock cable around
will have to find an adjustment thingo with more adjustment though just incase
Posted on: 2009/3/1 0:19
From SE Melbourne
Cool - I'll see how I go with this cable first - but I appreiciate the offer.
I just went through all pigdog's photos too and found nothing, then saw your post Nick...lol.
I'm even slower at building it now...I've got a baby in the house and a job with lots of travel - but it is pretty close to completion (I know I keep saying that).
Posted on: 2009/3/1 0:29
Mildman, Datsunless
From 6065
that looks like what ive done on the fatsun but mine is a 310 cable. i put a 310 pedal onto the 1200 arm that bolts to the firewall with a spacer cos the 310 pedal was smaller at the pivot point. then i removed the threaded bit the old cable screwed onto on the firewall,drilled 2 holes and was done,new style acc pedal! this saved me from cutting a hole for the std 1200 pedal when i fitted the new carpet from a vt commodore.(i didnt think it would fit as good as it does but cut the carpet in 1/4s and trim edges to fit and it pretty much drops straight in!) anyway now i'll probly have to change my pedal assy again when the L20s in.
Posted on: 2009/3/1 0:32
From hastings,vic
i used 1200 cable with ca end at engine mount, hq bonnet cable screw clamp pedal end
tommo
Posted on: 2009/3/1 2:56
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From SE Melbourne
So how hard is it to change the end of a cable?
and does someone have a pic of a 1200 throttle cable end handy?
I'm happy to swap a throttle cable for a clutch cable. [a 1200 one that is]
Posted on: 2009/3/1 10:09
Mildman, Datsunless
