Diff Type Help
From Adelaide
Howdy,
I don't know what diff is in my 1200 Coupe.
So I thought the collective brains trust of the Datsun 1200 forum might be able to help me.
I'd like to get some spare axles in case I twist one but it is a bit hard when I don't know where to start.
The housing has been modified and I can't find any serial or part numbers stamped on it.
The drum brakes have been replaced by disc. So looking at what the pads fit does not help
(120Y fronts)
I have looked at the diff centres I have and they don't seem to have any helpfull info stamped on them.
What I do Know is:
stamped on the crown wheels are
Diff 1
B37:9 EBL 859
37:9 is the ratio (4.11:1) but what does the EBL 859 mean?
Diff 2
HC39:8 CJ 1323
39:8 is the ratio (4.87:1) But what does
CJ 1323 mean?
Diff 3
B35:9 CQ 626
35:9 is the ratio (3.88:1) But what does
CQ 626
One of the centres has Datsun C20 van painted on it.
What I would like to know is what it is . . .
eg H165
what other ratios are avaliable . . . .
eg 4.65:1
and what cars they where fitted in.
Not asking for much am I . . . .
Here are some photos of one of the diff centres and the diff mounted in the car.
Thanks and any help will be greatly appreciated
Cheers,
Geoff
Posted on: 2009/3/8 0:56
Go Fast,
Or Go Home.
Re: Diff Type Help
Looks like H165. Is the ring gear diameter 165 mm?
B means B revision. HC means Hitachi C revision. A "B" carrier cannot hold "C" gearsets and vice-versa.
Posted on: 2009/3/8 1:10
Re: Diff Type Help
From Albury
Hi Geoff
8 bolts around the outside and it will be a H165 diff centre. The C20 van marking is also a giveaway. The housing should be a late model ute housing so axles will be the same. It theoretically could also be a C20 vanette diff housing which are wider and would need longer axles.
Cheers
Bob
Posted on: 2009/3/8 1:50
Re: Diff Type Help
From gold coast QLD.
The builders nailed it!
Good trip home?
Cheers
Posted on: 2009/3/8 6:44
Re: Diff Type Help
From Albury
Yeah Rob .Thanks for the hospitality and the Garage and vehicle tour.Highlight of the Gold Coast was 85mm of rain in a day.Just do not see that in Albury.
Cheers
Bob
Posted on: 2009/3/8 9:12
Re: Diff Type Help
From Adelaide
Thanks for the help.
Now I know what to look for.
Does any one know what ratios are available?
Cheers,
Geoff
Posted on: 2009/3/8 23:01
Go Fast,
Or Go Home.
Re: Diff Type Help
H165 Ratios are many, from 3.545 to 4.875. See H165
Posted on: 2009/3/8 23:09
