Head Bolts
Not too shy to talk
From Toowoomba
Does anyone besides ARP sell head bolts for the A series? And also the suppliers?
I cant afford $180 just at the moment...
Rather spend that money on a tough motor down the track...
Posted on: 2009/3/12 21:50
Re: Head Bolts
From gold coast QLD.
Nissan
Posted on: 2009/3/12 22:05
Re: Head Bolts
From Toowoomba, Qld
Go down and see Gary at engine Re-power, on Belvue street, near the underpass on Bridge street, he's got a bit of experiance with A series and can supply most of what you'll need.
He had a A14 freshly done sitting there for about $600 not so long ago, maybe ask if he's still got it?
Posted on: 2009/3/12 22:47
Re: Head Bolts
Not too shy to talk
From Toowoomba
Yeah, tried Gary... He's gone none in stock... That A14 would have been sweet but he's sold it...
Rang John Armstrong's Spare parts today ahd they were most un helpful...
Does nissan still make them? I've never had much luck with the Toowoomba Nissan dealership...
Anyone on here have any in good nick?
Posted on: 2009/3/13 0:38
Re: Head Bolts
Like i said ,Nissan.They'll most likely have to get them in ,but are still available as of mid way through last year.
Posted on: 2009/3/13 2:52
Re: Head Bolts
A-series head bolts are reusable. Just get a used set. All the ones from 1972 up are the strong type. From 1966-1971.5 are the weaker type.
Posted on: 2009/3/13 3:37
Re: Head Bolts
From Toowoomba, Qld
When I built my A15 I got all my internal bits and gaskets and new head bolts through 'Parts for cars' in Prescott St.
07 4639 1887
If you go in they might be able to help you out.
Posted on: 2009/3/13 3:53
Re: Head Bolts
From Toowoomba, Qld
If A15 ones are the same, I've got a used set here you can have if you want to come get them.
Dave. 0427 450 212
If it's urgent and it gets you out of trouble.
Posted on: 2009/3/13 3:55
Re: Head Bolts
From Townsville, Qld
I don't think you should re use the ones closest to the exhaust ports, they corrode noticalbly more than the rest of them.
Posted on: 2009/3/13 10:18
Re: Head Bolts
Not too shy to talk
From Toowoomba
I have noticed that there is one bolt slightly longer than the rest as well, like 10mm longer... Is that usual? If so, which hole is its home?
Posted on: 2009/3/13 12:53
