Radiator Alternatives
From Baraboo, WI USA
I am racing a 1200 coupe without a fan, and would like to increase the radiator size. Does anyone know of other OEM radiators that will supply better cooling without going to a racing specific radiator?bstarry@hotmail.com
Posted on: 2003/8/5 18:57
Re: Radiator Alternatives
Datsun B210 (B-210/120Y) and B310 (Sunny) all have a bigger radiator that more or less bolts in. Much better cooling.
Posted on: 2003/8/5 20:31
From Auckland, New Zealand
In my race car I run an "EG6" Honda Civic (V-tec) radiator & electric fan assembly.
These radiators are small but as they're made from alloy & plastic they are extremely effective. Another plus is that the total assembly (fan & radiator) weighs less that just the original radiator.
Posted on: 2003/8/5 22:04
From Perth W.A
a couple of the holden gemini ones fit not sure of the year but a couple do yeh.
hope it helps
Posted on: 2003/8/6 3:36
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Forget the other brands, stick with the Nissan. I have a turboed A14 with no intercooler and it runs at around 140-160 degrees f' I'm using a N13 alloy radiator from a pulsar. It cost me $110 from wreckers with a mark on it. I had to dint the inner guards with a little heat and a ball peen hammer. Then use a universal top hose from auto barn or Repco as the tubing out of the radiator the thermostat is alot different. It's been in the car for 4yrs. in Oct so its all good.
Posted on: 2003/8/6 5:07
GO DATTO GO!!!
From Palmerston North, New Zealand
What year and model pulsar??
Posted on: 2003/8/6 5:44
Ministock 9p
9p@ministock.co.nz
www.9p.ministock.co.nz
From Perth W.A
N13 is mid eighty's
Posted on: 2003/8/6 5:47
120y Coupe
Quite a regular
From melbourne
One suggestion that I make (and will save you a lot of tears) is if you buy a radiator from the wreckers it should be taken to a radiator expert to be checked BEFORE full cash price is paid,I have learned this the hard way.I used to run a mazda RX7 radiator in my 1000 coupe just cause I got it for free It was low,wide and worked a treat but did require pipe mods to make it work.
Posted on: 2003/8/7 12:50
From Canberra, Australia
Yeah. I just sued a gemini radiator. Cost me $20 from one being wrecked.Inlet and outlet are on the correct sides. Just use longs bolts and some tube steel as spacers.
Mine has not overheated since I put it in...
Posted on: 2003/8/7 13:38
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
In Canberra nothing would over heat at this time of year.
Posted on: 2003/8/8 2:03
GO DATTO GO!!!
