Re: Radiator Alternatives
From brisbane
Why not just fit a new 3 row core in place of the 2 row original? I've been quoted $300 for this with a 5 year warranty? I know it's more money but it'll look original and should theoreticely give you 33% more cooling.
Matty
Posted on: 2003/8/8 3:43
From Canberra, Australia
lsd wrote:
In Canberra nothing would over heat at this time of year.
Posted on: 2003/8/8 13:21
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From Melbourne, Australia
yep gemini, got mine for $20 eay to put in and should find a hose that is the right shape easy enough for the top (use 1200 original bottom hose)
Posted on: 2003/8/9 15:35
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Baraboo, WI USA
Thanks for all the input! I just ordered a new Pulsar radiator from RadiatorBarn.com for under $100 delivered. That should put an end to cooling problems.
Posted on: 2003/8/9 16:43
From Collingwood. Victoria. Aus.
Can you explain how the wiring is set up for your Honda Fan/rad assy for the fan to work??
Posted on: 2003/8/13 8:01
From Auckland N.Z
hey brent how hard was the honda setup to install?
Posted on: 2003/8/13 12:27
« 1 (2)
