carby hitting bonnet.
From sydney
atm i have a standard carby on my a15 in my 1200 ute. with the air filter on it just clears the bonnet by about 2mm or so. can somebody let me know if i swap to a 32/36 downdraught weber will it hit the bonnet. thanks
Posted on: 2009/8/25 9:41
Re: carby hitting bonnet.
From Melbourne, Oz
Nah shouldent do? lots hav done it. and I think the weber with the addaptor is about the same hight as the original carb. and most aftermarket fillters for webers are shorter.
Posted on: 2009/8/25 9:46
"I hav achieved wood"
From Sydney, Australia
..shoulda put a CA18det in
otherwise .. any chance you can slot the engine mounts to make it sit lower on that side?
Posted on: 2009/8/25 10:32
From sydney
yeah just my std carby is stuffed so im getting the ute right before i sell it.
Posted on: 2009/8/25 10:42
datto 1200 ute a12..low n slow (SOLD)
datto 1200 ute, a15 (SOLD)
fj20 1600 (SOLD)
CURRENT: 1200 Coop SR20de project Sleepin
Do you have the right bonnet?
It sounds like the engine is mounted too high. A15 with stock air cleaner, or A15 with weber 32/36 fits under the stock bonnet.
Posted on: 2009/8/26 3:47
From sydney
i dont have a stock air filter on it though i have a small sports chome one atm which is about 5-6 cm tall.
Posted on: 2009/8/28 3:31
fj20 1600 (SOLD)
The most likely answer is that when they swapped in the A15, they fitted it too high.
You can check: the bottom of the oil pan should be level with the bottom of the crossmember. If the oil pan is higher, that's your problem.
Posted on: 2009/8/28 6:57
