Temp Sensor Resistence Check ?
From Sri Lanka
Hi guys
I remember this was answered at once by ddgonzal, but i can't find that thread, what is the way to know engine temperature using a multimeter checking , what are the relevant values for low medium and high temp levels
thanks
regards
Sumith
Posted on: 2009/10/29 5:33
Re: Temp Sensor Resistence Check ?
I don't recall we ever got that information. We did get the temp gauge resistance.
1200 Tech: temp Gauge & Sender
Posted on: 2009/10/29 8:19
From Sri Lanka
Hi ddgonzal
Except this we discussed something that you told if the Ohm is 0 the engine is in the boiling state, something etc ? i dont know whether you or someone else exactly?
I checked my Thermal Transmitter in the engine with the multimeter when the engine is cold it is reading higher and when the engine is hot it is reading lesser figure in OHM , those values only i wanted to confirm
Thanks
Regards
Sumith
Posted on: 2009/10/29 8:58
From Perth WA AUS
That makes sense I think, if you connect the sender wire directly to an earth (-) the guage should read max temp (ie: less ohmn resistance)
Posted on: 2009/10/29 11:03
Datsun 1200 2Dr sedan.
From Sri Lanka
Hi levey
It is confusing think dude, in another web link , i saw if we connect sender wire to the ground and guage reads max , they mentioned it is DEFETIVE sender unit ,that is what i wanted to confirm
THANKS
REGARDS
SUMITH
Posted on: 2009/10/29 11:30
From Perth WA AUS
I might earth mine and see what it does, I'm not anysort of expert on this topic, but I figure the guage unit should be positive (+), the more negative (earth) it receives the more heat produced to bend the Bimetal needle thingy and the hotter the reading on the guage.
I might be wrong so some more feedback from other users would be great!
Posted on: 2009/10/30 11:31
From Perth WA AUS
OK, I earthed out my sender wire and the guage read max hot.
This method does nothing to tell you about the condition of the sender as its not connected at the time of testing.
I think you need a chart to tell you how many Ohms at a particular temperature etc.
Posted on: 2009/10/30 11:55
From Malaysia
Hi guys..
My temp gauge showing tat is always below C level...
When i measure the wire at the temp sensor,the voltage fluctuate...
Is it bad regulator in the meter??
Posted on: 2010/2/13 7:46
B110 1972 Modded A15
The voltage is supposed to fluctuate, because of the gauge regulator.
The sender works off restistance. Measure the ohms of the sender.
Accuracy Test
* Buy a 116-ohm resistor at Radio Shack or other electronics store.
1. At the engine, locate the thermal transmitter:
2. Pull the wire off the transmitter and put a 116-ohm resistor from the wire to earth/ground
3. Turn IGN switch to "ON". Gauge should read 50C/122F, or between C and H ranges (in middle range)
Posted on: 2010/2/13 21:34
From Malaysia
I waited the thermal transmitter to drop it ohm to around 116 ohm but the gauge shows at the C line.
Does it means my gauge are out???
Posted on: 2010/2/18 0:59
