A15 industrial engine
Not too shy to talk
From Sacramento, CA, USA. Where the tax dollars die.
Nissan A15 industrial engines are used in forklifts and other equipment. Has anyone looked at these? How much difference is there between them and the automotive A15?
Posted on: 2009/12/13 5:18
Re: A15 industrial engine
They are rated at 45hp. What else do you wish to know?
Posted on: 2009/12/13 6:33
From Melbourne, Oz
think the hav a steel head, with a (car) a15 head and probably cam and flywheel it would probly be the same.
Posted on: 2009/12/13 9:23
"I hav achieved wood"
They have an aluminum head. Yes, they are not much different to a car A15. Cam, head, exhaust, intake, replace the EFI with a carburetor, etc and you'd have a regular A15.
Posted on: 2009/12/13 18:31
From Tamworth , NSW
what kind of efi do they run?
im assuming its poop if you reckon a carby is better?
Posted on: 2009/12/13 20:46
some A15 industrial engines have a 45 hp efi.
Posted on: 2009/12/13 23:09
From Melbourne, Oz
The only two Iv seen with a15 still had carbs? looked the same as the car carb to.. not that that means much.
Posted on: 2009/12/14 6:48
Not too shy to talk
In searching for engine parts by part number I am finding them from forklift suppliers at much lower prices than from car parts suppliers.
Posted on: 2009/12/14 21:10
http://www.enginepowersource.com/html/nissan_a15.htm
rpms and hp figures are lower for the forklift engines
Parts are probably not designed for auto rpm redlines.
Whats interesting is the cg13 all alloy model is available with a
carby setup like some auto markets overseas and this engine complete
is 80kg and the a15 103kg, I know which one i would if aiming
for higher rpm output in a light car with 23kg advantage.
http://www.enginepowersource.com/html/nissan_cg13.htm
carby setup which I never though they did and this engine complete
Posted on: 2009/12/14 23:40
Not too shy to talk
The industrial engines are designed with low power for long service life. The power is reduced due to the cams, intake and exhaust. The Nissan part numbers are the same as automotive for bearings, oil pump, timing chain, etc, but half the price as a Nissan dealer.
Search a PN here
http://store.hgmforkliftparts.com/Default.aspx
Posted on: 2009/12/14 23:50
