Installing Distributer on TDC
From Sri Lanka
Hi Guys
My Piston #1 is in TDC Point,But when i install my Distributor it is not pointing to high tension segment How
should i get it to that point , Through the crank pulley or from the distributor it self ?
Thanks
Regards
sumith
Posted on: 2009/12/21 6:09
Re: Installing Distributer on TDC
To get the rotor to point to the correct high tension lead, rotate the distributor housing. If there is not enough movement possible, remove the distributor and replace it in a new position.
Details: Installing Distributor
Posted on: 2009/12/21 6:40
From Sri Lanka
Hi DD
As you said i installed the Distributor, just see any do you see anything wrong here ? we assume the no1 cylinder is just close to to therminal transmitter isn't it and also see the plug wire connection if you can please ?
Thanks
Regards
Sumith
jpg  Image022.jpg (18.32 KB)
10994_4b3048ed97b97.jpg 352X288 px
10994_4b3048fe93780.jpg 352X288 px
jpg  Image026.jpg (16.70 KB)
10994_4b30490a61aac.jpg 352X288 px
10994_4b30491a7a390.jpg 352X288 px
jpg  Image025.jpg (15.75 KB)
10994_4b3049396ae87.jpg 352X288 px
10994_4b30494d64fb2.jpg 352X288 px
Posted on: 2009/12/22 4:19
Do not ever assume when talking about timing.
It must be right, or the engine won't start. No 1 is the front cylinder. The rotor must point to it when the timing marks are lined up.
Posted on: 2009/12/22 4:26
From Sri Lanka
Thanks DD
So it is Clear, Distributer rotar Location is wrong in mine isn't it ? that is pointing Cylinder 4
Thanks
Regards
sumith
Posted on: 2009/12/22 7:24
Yes it looks that way to me.
How did you determine it was at TDC? When you line up the marks, it will at TDC of #1 or TDC of #4.
Just reverse wires #1 & #4, and #2 & #3. It may start up directly.
Posted on: 2009/12/22 8:05
From Sri Lanka
hI dd
I turned the Crank pulley removing no #1 Spark plug and kept a screw driver into it and let the piston to come to the top highest on it , that time the Crank Pulley is 5, so assumed that it is TDC, is it correct ?
thanks
regards
sumith
Posted on: 2009/12/22 9:21
No, TDC will be at 0 mark, not at the 5 mark.
Posted on: 2009/12/23 2:38
Find TDC of cylinder #1 by looking at the the valves and the timing mark on your pulley.
With the dizzy out of the car put the dizzy cap on (with the rotor in there a well) and mark on the outside body of the dizzy (with a marker or something) the centre of the number 1 contact (where you're going to put the number 1 high tension lead.)
Take off the dizzy cap and turn the rotor so it's pointing at the mark before sliding the dizzy back into the engine block. When you get toward the bottom the rotor is going to want to slide anti-clock wise (in the direction of the firing order) so you want to turn the rotor clock wise about 20 degrees or so. So when the dizzy is fully installed it is as close as possible to the mark you made before.
Put in the adjusting screw but leave it a little loose to fine tune the timing later. Install your spark plugs high tension lead and everything else you've disconnected.
Start the car and set your timing. I use roughly 10 degrees base timing at about 800rpm. Then set your dwell after that.
Posted on: 2009/12/23 6:55
Yes
Looking at the valves means:
1. Remove the rocker cover
2. Rotate engine until TDC marks line up
3. Check to see if both rockers for 1st cylinder have play
4. If they don't, rotate the engine a full turn
5. Verify that rockers for cylinder #1 have play
That's TDC of the No. 1 cylinder.
Posted on: 2009/12/23 7:06
