what head have i got?
From Tamworth , NSW
so, i have a spare head laying around and need help in identifying it.
i dont have any pics, but i went and took some measurements.
ive been thru the wiki and cant find anything close. dd or dodgeman might be able to give the good oil on this.
no casting numbers, just - NISSAN JAPAN
large oval ports - 39x30mm
exhaust ports - 29x27mm
inlet valve - 35mm
exhaust valve - 29mm
its got the double valve springs also.
ive had a real good look at the ports and they are stock. they have not been modified in any way, its still got the casting texture all the way to the edge.
any ideas??
Posted on: 2010/1/25 22:36
Re: what head have i got?
From gold coast QLD.
Lying around the shed ah? It,s a REAL GX
Posted on: 2010/1/25 22:49
If you are selling, it is a REAL GX.
If you are buying, it may not be.
See the Cylinder Head Identification guide. Yes it will take some work to figure it out.
From your brief description it most likely is an A12 GX head, or an A12T head.
Posted on: 2010/1/25 23:35
From Tamworth , NSW
no not selling.
i cant find anywhere in the head wiki with the same size inlet ports.
it doesent seem to match with anything.
Posted on: 2010/1/25 23:42
From Freo
are the water holes for the inlet manifold big or small?
Posted on: 2010/1/26 0:15
A15 PSI Project Motor
'72 CB750k,
Are the inlet ports higher on the head(closer to the rocker gear) than the garden variety oval port head?
Posted on: 2010/1/26 0:17
From Tamworth , NSW
the water holes are big, all four equal size.
i dont know if the inlet ports are higher than another oval port or not, i have another similar head at my brothers house that i may go over and measure this arvo.
its on what i assume to be its original 12 block.
the head also measures 74mm thick.
Posted on: 2010/1/26 0:29
From Freo
sounds GX all day long, the big water ports are the giveaway, oh and no casting number..
Posted on: 2010/1/26 0:38
'72 CB750k,
Those features all add up to an A12T head, which is better because it will work unmodified on early and late engines. GX head needs modification to work on newer engines.
Posted on: 2010/1/26 5:28
From Christchurch NZ
Good score! The seats should be able to be opened up to take the bigger A14/15 valves too.
Posted on: 2010/1/26 5:40
Forced Induction!
(1) 2 3 »
