(ca18det) brake booster
From sutho shire
hay as i have new disc's up front and have no booster yet with a ca18det installed not much space... i need a booster... i can get my hands on a 180b and a 120y booster but would like 2 hear from Ca peepz what they are running and what fits in that tight space...
cheers Andrew
Posted on: 2003/11/10 12:24
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
Re: (ca18det) brake booster
From Melbourne, Australia
id tell ya the sunny one is the pick of the bunch but i aint a "Ca peepz" so i wont
Posted on: 2003/11/10 12:26
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From sutho shire
cheers..
Posted on: 2003/11/10 14:27
Team New skool
From Sydney, Australia
Running a LA/LB Lancer Booster with a Nissan Master cylinder works ok, but that throws your clutch master cylinder plans into trouble.
I can say with some authority that running a Booster, and hydraulic clutch (with a CA installed), means a pedal box redesign.
Unless you remote mount the booster like the Escorts did. OR you remote mount the clutch master cylinder.
To move a 180B sized booster forwards anymore to clear the clutch M/C, means that the booster will hit on the strut tower.
There is no easy answer. Andrew (ca18detman) and his CA18DET survives fine without a booster.
Chris.
Posted on: 2003/11/11 0:07
Quite a regular
From Sunshine Coast
DVLDAT I would recommend a remote booster so that you have more room up front and it makes the enginee bay look neater. I am running a landcruiser master cylinder and will fit the remote booster when i make time. If it will help with your decision you can take my ute for a drive and see how they stop without a booster. They stop suprisingly well
Posted on: 2003/11/11 2:38
From Perth W.A
1200 ute in hot 4's was running a 120y booster and it was all good so thats my 2 non ca cents
Posted on: 2003/11/11 3:53
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From Melbourne AUS
u could run a booster if u went internal clutch master
Posted on: 2003/11/11 4:42
1973 B110 A12
I didn't think having clutch reservoirs or master cylinders inside the cabin was legal?
There is no way the guy had a regular looking clutch master cylinder, or was running the standard pedalbox if he was running a 120Y booster.
Chris
Posted on: 2003/11/11 5:08
yeah brake stuff in the cabin is all good, its just fuel connectors that are not
think vans and rallycars
Posted on: 2003/11/11 5:10
1200 Coupe Rallycar
From Auckland N.Z
speaking of vans the c20 van has an internal brake m/c set up which looks all good, check it out, I havent mesured anything to check if it fits but it might.
Posted on: 2003/11/11 6:22
