« 1 (2) 3 4 5 ... 7 »
Re: fitting trx rear brakes on 1000 front end. can this work?
From Wagga Wagga, NSW
Matto you legend! will 13's fit over this setup?
Posted on: 2010/7/21 11:42
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
From Adelaide, Australia
not sure. i dont have a 13 to try it with
Posted on: 2010/7/21 12:09
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
FUUUUUUUUUUUUUUUUUUU!
Posted on: 2010/7/21 12:18
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
all good ill suss it out :)
Posted on: 2010/7/21 12:19
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
From Geelong, Vic
only some 13 inch mags will clear them as they are rather large discs, about 280/290mm i think. bluebirds all run 14s or bigger standard
Posted on: 2010/7/21 12:42
From Perth WA AUS
Thanks Pigdog, I might look into that.
Posted on: 2010/7/21 12:49
Datsun 1200 2Dr sedan.
Tru blu conversion?
To think I spent months perfecting the Sigma setup and the blueys where
just staring me in the face all over the place the dirty cheap buggers!!!
So whats up with the trx caliper backing plate (alloy you mentioned???)
or are you using the drum backing plate??? that pic is not clear showing the back.
Posted on: 2010/7/21 14:48
Would you just be able to use series 3 bluebird rear setup aswell? i take it they would be roughly the same
Posted on: 2010/7/21 23:02
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
From Geelong, Vic
all of the rwd trx bluebird rear discs are the same
and D he is using the alloy bluebird backing plate and modifying that to suit the 1000 drum bolt patten
oh and just a little bit of info, r31 rear discs go onto a h165 pretty easily, so if h165 discs go on the front of a 1000 easy enough then you would think that r31 rears would also be able to be adapted pretty easily. and you can fit 13s over them piss easily and replace the handbrake caliper with one from a commodore to simplify it a bit
probably a bit more common then trx bluebirds
Posted on: 2010/7/22 0:08
From Geelong, Vic
also. if you want a caliper with a larger piston, im pretty sure that the smaller girlocks(from 200bs i think) go onto the metal part of the bluebird caliper bracket. or atleast the sliding pins were the same distance apart as the bluebird ones(or commodore ones)
Posted on: 2010/7/22 0:13
