Re: fitting trx rear brakes on 1000 front end. can this work?
That is impressive!!! Did the VS calipers bolt right on or did you make an adaptor?
It looks like its just part of the caliper frame.
when are they going on?
Posted on: 2010/8/4 12:16
From Wagga Wagga, NSW
I spoke to a mate whos into r31's and he told me of the vs caliper bolting right on and not having a handbrake assembly.
Going on my datsun 1000 ute
Posted on: 2010/8/4 12:19
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
What are the chances!!! excellent if they just bolt on the anchor plates just like that.
No handbrake assembly even better. Thanks for the pics
Posted on: 2010/8/4 12:32
From Freo
big fan of your work!!!, i have a pair of the brackets,
I'll look into some disk rotors.. :)
Posted on: 2010/8/4 13:16
A15 PSI Project Motor
'72 CB750k,
From Geelong, Vic
like i said on the second page, cant be too hard to fit R31 rear discs and use a commodore caliper instead of the R31 caliper...but no one listens to me
and i bet no one listened when i said that either 200b or corrona girlock calipers go onto the r31/commodore cast caliper half, the non alloy bit. then you can run a larger piston and larger pads
some mods maybe be required but the caliper pins are the same distance apart so it should be too much effort to get it to work
Posted on: 2010/8/4 15:18
Btw, you use the caliper from a commordore with a live axel and the caliper bolt spacing will be a 100mm ;)
Posted on: 2010/8/4 22:57
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
Nick the problem is until you own a 1000 we wont listen to you more than we should :)
Is there a way to rid the cast iron anchor plate and use an alloy one? getting anal now
and not the first time obviously :))
Posted on: 2010/8/5 6:18
No one listens to anyone!
Adam has done this one before on his KB10 and then used the same setup on the B10 4dr he bought off me. Not sure about the VS Caliper though, have to ask him.
Nice work Jake, even though it is the biggest thread hi-jack ever!
Posted on: 2010/8/5 7:18
From New Zealand
hey whats the OD of the r31 rear disk?
Posted on: 2010/8/5 7:32
260mm disk diameter, got hoses made up today and some brake lines
Posted on: 2010/8/5 8:49
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
« 1 2 3 4 (5) 6 7 »
