Re: Aspirated SR20
From Millgrove Vic OZ
There are a number of people who have webers on SR20DE's in the under 2 litre sports sedan class and have been very successful.
One example is in a Mk1 Ford escort and has 130Kw at the rear wheels. Not bad for old school carbs. It is still very driveable as well.
The jetting is easy. Using 45 webers with 42 chokes, F16 emulsion tubes with 165 or 170 mains and 170 air correctors 55 F2 idles and 45 pumps and you will be somewhere close to the money.
Cheers Feral Errol
Posted on: 2003/12/24 22:12
Cheers Feral
Re: Aspirated SR20
From Bridgetown, Barbados. W.I
so u are telling me there is no way i could get a fwd sr20 to fit into a rwd sunny
We will have to see on that one....is there any body here that has tried to fit a fwd engine into a rwd car.
What could be so different; the only things i see i will have to do is..
1) use webers as the intake is facing the firewall.
2) Fabricate engine mounts.
3) build a plate to bolt my ford 5 speed box unto
p.s. am i wrong when i mentioned the things i need to fit the engine.
Posted on: 2003/12/24 23:04
Life's better SIDEWAYS!!
Re: Aspirated SR20
From Wellington New Zealand
should be fine! I cant imagine Nissan making huge changes to blocks for RWD/FWD.
The block from the GTiR is different however...
I put a FWD CA16 in a 1200 with 45 webers, no real problems except for keeping oil in it. Used a ford box too!
Posted on: 2003/12/25 1:09
Re: Aspirated SR20
From Okinawa, Japan
I'm told the gearbox mounts are different and so is the pilot bushing... should be able to make an adapter plate for a RWD tranny and make an acceptable bushing though.
Posted on: 2003/12/25 2:19
Re: Aspirated SR20
well since the fitting problem is solved.
Do u guys think 200hp could be made from an aspirated sr20.
Also if it is possible, what parts and work must be done.
thanks.
Posted on: 2003/12/25 12:01
Re: Aspirated SR20
From Okinawa, Japan
Here's a look at the tomei site... 200 hp mark should be easy. tomei SR20DE
Posted on: 2003/12/25 13:34
Re: Aspirated SR20
are they any sites out there that could give me step by step build up of a high powered sr20de.
thanks.
p.s. does anyone know how much HP an early 90's sr20de makes. Is there any sites that can give u the specs for the sr20 engines in the years they were made?
Posted on: 2003/12/25 21:28
Re: Aspirated SR20
Posted on: 2003/12/25 21:37
Re: Aspirated SR20
Check this site out, there is a lot of good info there. SER.NET
Posted on: 2003/12/26 20:59
Cheers Feral
Re: Aspirated SR20
turbo chargind the de seems a bit confusing so i think i will stick with it being naturally aspirated and using carbs.
p.s.Are they any alternatives for a sr20 flywheel as mines was an automatic. Does nissan have any 8 bolt flywheels that could work other than the sr20's that would be of a save weight region, as it seems difficult to get a flywheel from here.
thanks.
Posted on: 2003/12/30 0:46
« 1 (2)
