Re: A15 Race engine tips
From sydney.nsw
all of the after market heads are designed with a very high roof in the ports. this allows the so called short turn to have a lot larger radius, which makes the head flow alot better, the ports are all about raising them,and making the short turn less of a right angle turn.the problem with a series ,is that you often you hit water when raising port.takes lots of time ,welding and experience to get it right.lots of power is made by the head and a number of other things. a good engine, is a combo of a everything.to many to list.(been there done that) cheers ernie
Posted on: 2010/11/20 11:30
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
love this!!!
jpg  rc.jpg (37.50 KB)
737_4ce8270130921.jpg 456X203 px
Posted on: 2010/11/20 19:51
Not too shy to talk
Good you like, thanks. I was thinking that is there any thought that i fit some another car tecknics in that little car?? And what that can be?
T:kimmo
Posted on: 2010/11/21 19:39
Not too shy to talk
Is there any help use roller rockers?
Posted on: 2010/11/21 22:18
Not too shy to talk
From Ronse,Belgium
Nice car you have there.I have not been racing mine for three years now,it is about time I start putting it back together (when I think about it that is when I bought and started restoring my 1200,now that I am driving it the interest in racing has somewhat vanished,or maybe it is age?).Can you give some more details about your car,like what you have for brakes,suspension,gearbox?
Posted on: 2010/11/21 22:57
From Tasmania
I think we should start an E10 race/fast car topic on here. I want to know more about all these E10's and there set ups.
Posted on: 2010/11/21 23:14
Proud member of " The Tasmanian Datsun Owners Group"
From Las Vegas USA
I think just going to a more stout connecting rod, carillo etc., in conjunction with your existing specs should work well. Roller rockers will help eliminate some frictional losses.
What rulebook do you have to stick to? FIA spec, local group etc. The A=series build is well documented: In the U.S. A-series engines use the race/GX head with bigger valves, 14-1 compression, .495 lift with 300 degrees duration camshaft, Weber DCOE carbs (40mm or bigger), roller rockers, crank fire ignition, dry sump & 7lb flywheel. This makes 100HP at the wheels for an A12.
If you're only restriction is a stock block then you could do some radical things like configuring the port angle.
I'l also curious about what gearbox, etc. is in your car..........are there close ratio boxes availible for FWD as well as limited slip diffs?
Tom
Posted on: 2010/11/21 23:21
From Tasmania
Mine only has a standard N10 pulsar 5 speed gearbox there was other gear sets originally made for the factory race cars and an LSD (rare as rocking horse poo). Mine is to be used for hillclimbs motokhana's and maybe a track day or two.
Posted on: 2010/11/21 23:39
Not too shy to talk
I have mazda 323 front brakes and disk, rear vw golf brake and disk. Spax dampers, cherry n10 5 speed gearbox, toyota starlet limited slipp diff, gearbox is modifield for race. Engine have megasquit fuel injection.
t:kimmo
Posted on: 2010/11/22 11:56
From Tasmania
I have stared an E10 thread if you want to post some more pics or information in there.
http://datsun1200.com/modules/newbb/v ... id=347048#forumpost347048
Posted on: 2010/11/22 19:30
« 1 (2) 3 4 5 »
