Re: tie rod to strut issues
From Townsville, Qld
I like the pincher style ball joint remover, it could stay in place while you slowly wind the nut in. Mine broke however since it was a cheaply cast item from supercheap so I went to a sent of Teng tool prong styles. Haven't used them in the confines of the car but they're not too bad
Posted on: 2010/12/24 23:43
From Rosewood, QLD
i have been defeated.
cannot remove lower passenger tie rod end.
cannot remove upper tie rod end.
now looking into buying tools.
not happy.
Posted on: 2010/12/26 9:25
1971 B110 sedan project.
2012 Nissan Micra daily.
From Rosewood, QLD
there seems to be 2 different kinds of tool for this job, one wedge style which you hammer in and seperet that way and the other has a kind of clamp with a screw to press the rod out... im confused as to which one will be more effective.
Posted on: 2010/12/26 9:29
i used the fork style one on my inner tie rods with great success. never had an issue with the outer ones, the hammer method worked on the outer ones every time.
Posted on: 2010/12/26 10:50
From Ringwood, Melbourne, AUS
The clamp type one is better if you are going to re-use the tierods/ball joints etc., as the fork type usually #OOPS#s the rubber boots..
Posted on: 2010/12/26 10:55
Deano
From radelaide
we have a saying in my trade
"If at first you don't succeed try a BIGGER Hammer" lol
Posted on: 2010/12/27 1:02
HY_FLO MOTORSPORT - designing a new wave in motorsport
hy.flo912@gmail.com
0411 725 347
www.facebook.com/HyFloMotorsport
FOLLOW ME
They both work well
* Pickle fork (wedge) fits many sizes of joints. You still need a hammer.
* Puller fits only certain sizes, but doesn't damage the grease covers. You need a wrench to turn it.
Posted on: 2010/12/27 3:05
C'mon Ziggy harden up mate.
As Dattodude said hold one FBH horizontal and stationary against the steering arm next to the nut and use another hammer to hit the arm on the opposite side. Mostly people are not successful as the hammer blow is not square to the stud axis and the energy is lost. In 35 years I've not seen one that will not come out if done correctly. Stubborn maybe but they all come loose. Hope this helps.
BTW guys heating forged steering components is a VERY large no-no.
Posted on: 2010/12/27 6:41
From Rosewood, QLD
haha cheers guys i still cant win, im going to a couple tool shops tomorrow i hope and getting some kind of tool, both styles seem good ill just have to decide on the day, ill also need a new tie rod end cus in my fury i damaged the boot with a screwdriver trying to pry it loose a bit... then i smashed the thread directly with my hammer without the nut left on it.... yes i am a goose and yes i feel embarrassed that i cant seem to do this.
Posted on: 2010/12/27 7:02
From SYDNEY,NSW
i have also ruin the thread on one, skacking it with a hammer like everyone says to do :( learned my lesson with that one..
hit up superheap, they have the tool for about 8 bucks.
Posted on: 2010/12/27 11:03
vouch points for PIGDOG J-Dat dats-me TRAV 40RST minitruckin 120fly DEMO 1200dat aidaniel matty discobob mick1200 cemax DATSKOOL - all have helped me out with parts...Thankyou
« 1 (2) 3 »
