« 1 ... 7 8 9 (10)
Re: s/charged a14
From Gold Coast Aust
Kegs I take your point and I'm sorry for any ofence Have a read of the tech section on supercharging The set up I used was/is cheap Subaru Vivo blower $350 pulley and adaptar plate $150 Idid make my own inlet manifold But Iam sure it would work with a standard one and for a carby use a holley 320 so you can get out of the hole thing doing the work youself for under $900 Aud
Posted on: 2004/1/28 11:32
Datsun 1200
Keepin' the past in the future
Re: s/charged a14
From campbelltown (sydney) australia
#### 900 bucks damn i dunno im planning on making all custom piping my dad can weld all piping and that my s/c is 350 bucks for 2 litre one, gonna cost heaps for headwork and that i was looking at around 2 grand for the setup. holey 320's are good huh? aight thats an option im gonna use su to start with ive got some 600cfm carter carby at home haha maybe have a fiddle with that one eh.
Posted on: 2004/1/28 11:59
Re: s/charged a14
I've had my fun with my set up and I'm going back to an early 1200 motor stock as even to the paint so you can buy my set up for $3500 and that will get you the engine as well
Posted on: 2004/1/28 12:06
Datsun 1200
Re: s/charged a14
my suggestion is ditch the stock 1200 idea get it registered with 1200 but then make up all mounts and that to fit small block v8 in ur wagon bit, make removable top so u can work on it, make it so u can take the engine out real easily. then blacken ur windows and race ppl hahaha ull never lose.
Posted on: 2004/1/28 12:16
Re: s/charged a14
I'm needing to bring the wagon back to a stocker the reason that there are no stockers around then I will have something different. My ute is my latest toy.
Posted on: 2004/1/28 12:22
Datsun 1200
Re: s/charged a14
yeah the utes are the best, here we go im gonna cop it for that. my ute has the show but now im concentrating on go its no good with a12 and slipping clutch.
Posted on: 2004/1/28 12:26
Re: s/charged a14
Quite a regular
From Adelaide
Has any one used the low compression a14 oval port head, stamped h72.Will the fact that it has an open combustion chamber affect its performance when supercharging.
Posted on: 2004/3/2 3:50
Re: s/charged a14
From Christchurch NZ
Maybe I did. I used an oval port head, and I think from memory it had the big chambers. I put it together before I found this site so I dont know what the h# was , but if I pull of the rocker cover Ill let you know.
If your wondering about the comp ratio, with a 1.5 mm head saver shim it was 7.9:1.
Posted on: 2004/3/2 5:11
Forced Induction!
Re: s/charged a14
Quite a regular
From Adelaide
cheers for that a14 force,
looking to find a way of getting comp down without using a15 /a14 crank and i rekon that will do the job nicely.
Posted on: 2004/3/4 4:12
« 1 ... 7 8 9 (10)
