Hidden Agenda - Steel rocker & home made goodies
This is my take on the steelie rocker cover
to make is look much longer and less cluttered.
Its about hiding everything I can away to clean
the view. I call it the "Hidden Agenda" where all
the wiring is also hidden.
The breather hose will be at the back, Accelerator
cable will be a challenge but plan to use a bracket
off the side of the head where there is a thread.
Fuel line will run round the back with carb fuel
nozzle flipped so it runs under the carb box.
Almost finished, needs one final coat of paint and
the Datsun bossing to be hand painted in silver.
jpg  steelie rocker.JPG (138.56 KB)
737_4d888fc82dab3.jpg 903X380 px
jpg  rockercoverpre.JPG (64.13 KB)
737_4d8f0bca44356.jpg 501X212 px
Posted on: 2011/3/22 12:02
Edited by D on 2011/3/22 22:53:38
Edited by D on 2011/3/22 22:54:31
Edited by D on 2011/3/27 7:29:28
Edited by D on 2011/3/27 11:05:02
Re: Steel rocker cover with a difference
From Snohomish, WA USA
Looks nice. I like the Datsun covers. All the A series B210 and 210 covers say Nissan. I only have one of the Datsun covers and it came off my A12. Used it on my A15 setup.
Posted on: 2011/3/22 16:13
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From Rosewood, QLD
yes!!! i like this idea
Posted on: 2011/3/22 20:10
1971 B110 sedan project.
2012 Nissan Micra daily.
Zig Zag,
I wrote a long PM about the alt bracket and alternator upgrade and when I use Firefox the PM dont get sent and sometimes I dont received them.
If you slice off with a grinder or hacksaw the rear section of the long bolt for the alt adjustment a camry 87-92 alternator will fit comfortably. Just place the alt above it and you will see the distance required to be taken off. Even if you take off too much you can use a washer to correct it. You can also fit a mitsubishi type alternator found of 84-86 mazda 929 the same way and follow the wiring diagrams on the wiki where 2 wires are connected to remove ext. reg. These Alts have have internal regs, fans and make 65 amps enough for most add ons. late racket is cast iron but works well cut up.
Will put other pics of the alt upgrade on the early model this time. Rest of the Hidden Agenda process for the 1000 also. Simple as they are I want to go further and cleaner unlike the state of my mind(s).
Ernie, I also prefer Datsun insignias will do it for the CA18 rocker also.
Posted on: 2011/3/22 22:52
Re: Hidden Agenda - Steel rocker customized
From Freo
almost clean enuff to slap a Carbon mould off it.. ;)
Posted on: 2011/3/23 2:31
A15 PSI Project Motor
'72 CB750k,
Carbon fibre! so much for old school :)
pic of final black coat on and writing in silver chrome soon
Posted on: 2011/3/23 3:46
From Rosewood, QLD
haha D yeah i thought the mail must have gotten lost somewhere and was going to just leave it til i got closer to attempting it to contact you again, cheers for the info ill have to give it a crack
Posted on: 2011/3/23 8:32
Todays lil progress shot
jpg  blkrock.JPG (169.54 KB)
737_4d89db77b0f2f.jpg 1002X394 px
Posted on: 2011/3/23 11:37
That might fit a 1000, but is there enough room on the back for a 1200?
Posted on: 2011/3/24 4:30
I think theres more room in a 1200 hence the L series a much longer beast
fitting easier. At worst it would be easy to fit a straight brass threaded
tube it just that I had this one available at the time.
I used 2 pack steel putty to seal up the top breather and a thin bog layer.
Posted on: 2011/3/24 4:54
