Re: Strop's 'Daily' Driver - 1200 Ute A14
Quite a regular
Where did U get that inlet manifold (pic 23) ?
ZM
Posted on: 2011/2/5 23:10
Quite a regular
Shifty wrote:
Very cool! I'd love something like this, the only thing putting me off is that they can't pull a car trailer!
I've had heavier weights than that on the back of my 1200 sedan in the early '90s! Used to just load the back seat and boot up with weight (cable) first. Needed both feet on the brake to stop it though!
ZM
Posted on: 2011/2/5 23:13
From Central QLD Coast
Hey Zord, that manifold was the original one that had the 'bige' treatment, blasted and welded up.
Posted on: 2011/3/9 0:04
Been busy with life for the last couple of months, so annoying.
Will hopefully get a chance to work on the car this month.
So i'll have a shot at porting the manifold for the webers and installing them this week. The linkages were fun.. I'll prob be looking to move the 32/36 weber on once all is ok.
I have also started collecting for the next project...slapping a CAdet conversion into the ute.
jpg  photo 36.JPG (190.32 KB)
13253_4d76c59cc0395.jpg 480X640 px
jpg  photo 37.JPG (189.60 KB)
13253_4d76c5e0198db.jpg 480X640 px
jpg  photo 38.JPG (196.27 KB)
13253_4d76c6099a77b.jpg 640X480 px
jpg  photo 39.JPG (160.71 KB)
13253_4d76c68b48a03.jpg 480X640 px
jpg  photo 40.JPG (91.38 KB)
13253_4d76c8b87a889.jpg 640X480 px
jpg  photo 35b.JPG (60.25 KB)
13253_4d76ca6165f79.jpg 240X320 px
Posted on: 2011/3/9 0:31
Hmm, I think I hate redline. Had to do sooo much work to the mainfold just to make it fit.
But it is on and i'm happy, guess that is the main thing. Finished getting the DCOM's on this arvo, just gotta tune it after I set up the idle screw. Started it and it sounds great and so responsive.
jpg  Webers4.JPG (110.60 KB)
13253_4d9317b999cd6.jpg 640X480 px
Posted on: 2011/3/30 12:46
What should I expcect from this engine, HP wise? It goes on the Dyno on Thursday for a tune.
Any guesses?
Posted on: 2011/5/10 8:52
There is often additional work to get manifolds to fit, flange thicknesses, flanges fouling etc etc but if it's any consolation even Bpro manifolds need a bit of a tickle up to make fit nicely. It comes down to the flange profile of the headers as well.
As for power it's a hard one to pick without the list of specs on the same page but that cam has some decent lift (8mm) and the duration looks fairly broad too? Whats the ignition setup? (sorry if you mentioned it before).
Did Ernie sought your cam as well?
Posted on: 2011/5/10 9:10
From Sydney
77hp atw
Posted on: 2011/5/10 9:11
From mandurah
This is a great build page ,realy nice engine ,and those carbs look shmicko
Keep it up !
90hp atw
Posted on: 2011/5/10 10:05
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From sydney.nsw
good to see things going well,put up dyno figures once done(rpm/torque/hp) my WILD guess is 96.7HP at 6800rpm for a a14. GOOD LUCK
Posted on: 2011/5/10 10:22
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
« 1 2 (3) 4 »
