coil how much volts?
From vic
hi i was checking how much volts i get at the coil and the ballast resistor and with my multimeter i only get a reading of 3.8V does this sound right i thought it was supposed to be 12V
but there is no problem in engine starting or anything i was just checking how much my carb auto choke was getting!
Thanks!
Posted on: 2011/6/4 6:38
Re: coil how much volts?
Ballast resistor reduces voltage, that is its purpose, because points cannot handle 12v for more than a few seconds.
If you are using points distributor, connect e-choke to the 12v side of the resistor.
Posted on: 2011/6/4 7:12
From Adelaide
Are you testing it with it running? Multimeters wont give as meaningful reading with pulsating current. With the ignition on and the points closed it should read around 6 volts but your points will get hot. If you google kettering point ignition you'll find out about how it all works.
Posted on: 2011/6/4 8:52
From vic
i tried with it running and not running and both gave me readings of 3.8V
Posted on: 2011/6/4 9:39
No worries.
Posted on: 2011/6/4 9:49
