« 1 ... 10 11 12 (13) 14 15 16 ... 42 »
Re: 1200RallyCar - My road car rebuild - 1200 coupe
From Central Coast NSW
intresting about the surge tank , im pretty sure mine is the same one , but is mounted flat in the boot(hidden behind the tailights garnish)works so far, car has ran for a short time(no exhuast). but ill see what happens in the long run....
deff black out all the cooler and piping :)
Posted on: 2011/3/15 13:28
From Melbourne, Australia
Finally i can give some progress again.
Had some help from a guy at work, he fabricated a turbo outlet and a battery tray for me, pics to come
had an engineer come round and check it out, got a short list of things to get it legit;
-swap engine x-member to other one i have which is much better
-change gearbox x-member from maddat style one becuase bolts through floor not ok
-7/8th master cylinder for brakes
-extra strength for front seat front mounts (casuse aftermarket seats)
-cat/charcoal and oxy sensor
otherwise all good with brakes/struts, h190, intercooler etc
so pretty happy that i will be able to engineer as soon as i get it going really
going to do gearbox like an old picture pigdog posted with cups welded to the floor which retain captive nuts (other option is to bolt to chassis rails)
Posted on: 2011/6/23 12:59
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Cups, why not just weld in stock tunnel mounts. He liked mine
Posted on: 2011/6/23 13:01
Chassis gearbox mounts allowed are surely welded not drilled on ones?
Posted on: 2011/6/23 13:47
From Melbourne, Aus
good to hear the project is progressing.
Who is the engineer that you are using?
Posted on: 2011/6/23 21:18
unfam can you show me a link to a photo? couldn't find it in your build thread. using Sanjay. chassis mount for gearbox was suggested to be bolted through horizontally - i prefer the other option
Posted on: 2011/6/27 4:48
1200 Coupe Rallycar
So is any strengthening of the radiator support panel required....as yours seems to be cut exactly the same as mine and Sanjay specified inch x inch rhs uprights be installed where the rad support had been cut.
Posted on: 2011/6/27 8:42
havent got a pic mic... just the stock mounts in the tunnel cut off and rewleded on where needed.
Posted on: 2011/6/27 10:32
yay some solid progress yesterday, brother came around with welder to help me get some jobs done
battery mounted in boot very nicely
temporary connection from 3 inch dump to the old 2 inch system to get it up and running
filled in and strengthen some rad support areas, allowing me to get onto mounting of intercooler and radiator
have taken all dimensions to get a clutch hose made to complete that, and get a tailshaft made to complete that...
whats left
minimal wiring (from battery to starter and power wires to ecu/loom etc and wiring of fuel pump and thermos)
mount intercooler and radiator and plumb them up
put dash and seats back in
plumb oil and water lines to turbo
airbox (prob do similar to tomoz)
sort out a shifter
hmmm... a bunch of little things....but not a great deal more than that
Posted on: 2011/7/25 4:20
1200 Coupe Rallycar
Well good work. Now finish it lol
Posted on: 2011/7/25 4:45
