Alloy Head gone Soft??
I took my A series head into a machine shop this morning. It was a bit compressed under the head bolt washer between the exhaust ports on 2nd and 3rd pots. He then got a little bouncy ball in a tube( ACL Hardness tester) and checked the head all over and it has apparently gone soft . Has this happened to anyone before with an A12 . It seems very feesable. He said not to use it at all?? Has anyone used a soft head? Just would like a 2nd opinion as some machinists can get a bit OTT.
Posted on: 2011/6/30 5:59
Re: Alloy Head gone Soft??
From Sydney
get it re-tempered. Not that expensive....
Posted on: 2011/6/30 6:28
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
What does re-tempering invole?? Do machine shops generally do this??
Posted on: 2011/6/30 6:52
From Melbourne, Australia
its an a12 head... cheap and easy to get.....just get another one.....
took 3 attempts for me to get one that wasnt soft when i was looking to get one rebuilt
why root around with one thats stuffed?
Posted on: 2011/6/30 7:14
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From mandurah
Ive got a good complete a12 head for sale ,PM me if your interested :)
Posted on: 2011/6/30 7:24
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From sydney.nsw
not worth it, put the h 89 on it or another a12 head, to temper a head,first it needs straightening,then all metal needs to be removed(studs/guides/valve inserts/welsh plug),after heat treating is done, all metals need to be re fitted/machined, then p/test & head service.(expensive cost for a a12 head).
Posted on: 2011/6/30 7:40
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Why do you say "not worth it"? What has actually happened when using a slightly soft head?
Gasket manufacturers says don't use the head if it is under 65 Brinell hardness. But new they may only have 80 hardness...
Posted on: 2011/6/30 8:05
From sydney.nsw
good s/hand a12 heads here are worth $50-$150,why would you go to all that trouble/cost to re do a soft one.
Posted on: 2011/6/30 8:09
By the way, heads don't go soft from age, or from engine overheating. They get soft when a machinist tries to straighten a warped head and heats it in an oven. Softening begins at around 290-310° C. Machinist should never heat a head this hot, but sometimes they do and it softens the head.
Posted on: 2011/6/30 8:12
Agreed, spending all that money on rebuilding. But the question is "Has anyone used a soft head?"
Posted on: 2011/6/30 8:14
