ca18 question
From Goulburn NSW
Hi guys and girls was tinkering with my ca today was wondering do they have spark plugs they should be inbetween the rocker covers,obvious i know but couldnt work out how to get to them.
Posted on: 2011/9/27 9:28
Re: ca18 question
Start unwinding screws and you will get there :)
Thats how i figure out things
Posted on: 2011/9/27 9:59
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
Re: ca18 question
From vic
you remove 8 philips head screw in the middle of rocker cover (black plastic cover) than you will find coil packs with 16 screws but only remove 8 so first 2 then skips 2nd lot go to 3rd and take out 2 scews skip 4th and go to 5th so on!
edit: maybe that part was not explained properly its just remove all screws on the plate that holds the coil pack dont unscrew the ones on the coilpack (just the plate)
and it should come off with the red boots and thiers your spark plugs!
Posted on: 2011/9/27 10:15
Re: ca18 question
From Goulburn NSW
thanks guys,so they have individual coil packs instead of one coil.
Posted on: 2011/9/27 11:14
Re: ca18 question
From vic
yes they have a coil pack for each cylinder!
Posted on: 2011/9/27 11:22
