Re: How do you guys get traction with high hp? And awd anyone?
I thought I posted this reply a day or so back, but it didn't show - I have been working long hours, so maybe I forgot to hit send or something. Anyhoo, here is the post:
I'm simplifying the tech stuff below - it's 'right' there's just a few minor other issues which affect overall grip (tyre hysterisis for one) but relatively speaking it is minor, and the 'main' issues are hte ones I mention below.
believe it or not, tread width isn't the big deal here. It's friction co-efficient of the tyre tread compound (apart from chassis/suspension tweaks to maximise downforce/grip)
Here's the deal - IF (and it's a big if) the tread compound is identical - then a 235 will provide exactly the same grip as a 195 width tyre. The reason is simple enough. Grip is a result of teh combination of 2 things - downforce and friction co-efficient. If you have the same tread compound, but halve the width, then there is double the 'load' on each square cm of tread, so it basically has the same grip.
Obviously you can get to a thin enough tyre where it'll just overheat too quickly. And it'll also wear out quicker (since at half the width, it'll have half as much tread area to wear down). Since thinner tyres will experience that, very generally, the tyre makers run harder compounds in thinner tyres, and can 'get away with' softer compounds on wider tyres and still have acceptable tyre life.
So in general, wider tyres 'might' grip more, but it's only because they were made with softer grippier tread, not just due ot the width all by itself.
The reason I mention this is pretty simple - it is probably now obvious - it's not so much a matter of finding 'a' tyre in 225 or 195 or whatever the widest width is, the REAL trick is to look at each individual tyre in the sizes that will fit, and find the ones with the stickiest tread compound.
Now, even people who compete in short sprint races can overcook their tyres, so you have to try and find a balance between tyre life, the traction you need, and how long they will be good for 'thrashing' around before they start to go off a little due to overheating. As a good example - this is why the smaller cars (relatively speaking) tend to do so well compared to the big ones in Improved Production - the tyre sizes are too narrow (relatively) for the bigger cars and they overheat after a couple of laps, so the drivers have to nurse them a lot more. They can't 'really' use grippier compounds, because the tyres/compound are a regulated item.
But on a streeter, you can find a happy medium (if you are willing to go through tyres perhaps every 5-10,000km)
So now on to chassis/suspension. One of the critical things (aside from axle tramp, and there's plenty of discussions on here about caltracs/anti-tramp bar fabrication and fitment) to do is to make the car's intertia help to push down hard on the rears when the car launches.
TO do this, you need the front leaf pivot point to be higher than the axle centre line. then the leaf moves slightly 'uphill' toward the front. This is important because when the axle is pushed forward (as you launch) it'll try and 'lift' the car (since that slight angle translates into a slight upward force). So if it is trying to lift the car, then it has to do it via 'pushing down' on teh rears. The car won't (usually) actually lift up at the rear, instead as the rears push forward, the inertia of the car body/chassis tries to push rearward, and so this then pushes down harder still on the rear tyres. The car itself won't (when setup right) massively lift or squat down at the rear but the FORCE applied pushing down on the rear wheels will be maximised.
The reason i bring _that_ up is that often if a car is lowered, you can end up with the axle centre line being higher than the front leaf pivot point. If that is the case, instead of it 'increasing' downforce, it actually 'unloads' the tyres and makes it easier for them to lose traction and continue not to grip.
So you need to either have the car ride height set high enough at the rear to allow the front leaf pivot point to be higher than the axles, or if that is too high, you'd have to look at shifting the front leaf attachment/pivot higher up in the chassis (not exactly an easy option a lot of the time). At the very least, keep 'lowering blocks' well away from it.
Aside from the lowering blocks setting the axle centreline too high, the further you raise the axle tubes up away from the leaf springs, the more 'leverage' the diff has to twist and wind up rthe springs, so it'll also increase axle tramp (which itself will compromise launches).
The same thing applies to various 4 link/control arm rear suspensions, the math angles are perhaps a little different, but the overall principle applies.
so as bad as it sounds, often the loss of traction is just as much to do with a car being 'too low' and ending up with undesirable suspension geometry as a result.
When it comes to circuit racing, you'll find that you might end up wanting it a little lower than would be ideal for straight line, and as a result you'll get good cornering/mid corner speed, but might start to compromise corner exit speed as it just won't grip enough to leave the corner hard enough. TO that end, obviously you'll have to test and come to the best combination of mid corner vs corner exit speed and straight line grip off the mark. For most circuit racers, grip off the line isn't as important, as you only do that once - at the race start, so a lot of them sacrifice their launch potential for better lap times for the rest of the race.
Obviously you can also look at stuff like less rear sway bar and or thicker front one (if they are fitted front and rear) to try and get better grip out of the corner (but it might affect turn in a little - hey everything on a performance car is a combination of compromises!). Additionally, you could also look at adjustable rear shocks, and in particular (if it is still too slippy out of a corner) look into softening the rear rebound damping. This will tend to make the car get more grip out of the corner, but ironically because it grips better and doesn't mildly oversteer out of the corner as much, it can actually 'feel' slower. But it will be quicker lap times (obviously experiment to find the ideal setting).
What else - I highly recommend 'tune to win' by Carroll Smith. It discusses car suspension design and optimising for racing. Admittedly it is a few years old now, but 99% of the info in there is absolutely gold. About the only thing it doesn't have in quite the same detail as we might like is shock absorbers (it does discuss them pretty well though) and this is simply because at the time the book was written, fully adjustable shocks existed, but were miles away from the current stuff. Also - the tyres he discusses were race tyres of the era, and differ from street oriented radial tyres. The general info is all accurate, but the inflation pressures are night and day - street radials don't grip better with low pressures, etc.
I'd actually recommend all of Smith's books. Drive to win is all about how to get sponsorship etc, as well as how to drive. It's also amusing in some parts. Tune to win is everything about setup/adjustment for optimal track times. Engineer to win is about race car construction - various metallurgy stuff, relative strengths/thicknesses of mild steel vs chromoly (for example, chromoly is stronger so thinner wall thickness can be used, but when it is in a collision, it is more likely to break and leave sharp edges, but mild steel will tend to flex/bend instead. So it can actually be safer, albeit heavier). He also did a book on nuts bolts fasteners.
I've got the books. Someone mentioned to me that tune to win might be available as a torrent on bitsnoop, but I haven't looked and I absolutely am not suggesting or condoning any illegal download. Apart from it being 'unfair' in a general sense, I honestly reckon the books are so packed with info, that they are worth every dollar ten times over. Maybe someone out there might (hypothetically, but not in the real world) download the torrent, just to check it out, and then are so impressed by it, they purchase the book(s)
Posted on: 2011/11/8 10:30
John McKenzie
or you could just buy a factory 4wd sunny.otherwise known as nissan GTiR
Posted on: 2011/11/8 10:53
I thought I posted this reply a day or so back, but it didn't show - I have been working long hours, so maybe I forgot to hit send or something. Anyhoo, here is the post: I'm simplifying the tech stuff below - it's 'right' there's just a few minor other issues which affect overall grip (tyre hysterisis for one) but relatively speaking it is minor, and the 'main' issues are hte ones I mention below. believe it or not, tread width isn't the big deal here. It's friction co-efficient of the tyre tread compound (apart from chassis/suspension tweaks to maximise downforce/grip) Here's the deal - IF (and it's a big if) the tread compound is identical - then a 235 will provide exactly the same grip as a 195 width tyre. The reason is simple enough. Grip is a result of teh combination of 2 things - downforce and friction co-efficient. If you have the same tread compound, but halve the width, then there is double the 'load' on each square cm of tread, so it basically has the same grip. Obviously you can get to a thin enough tyre where it'll just overheat too quickly. And it'll also wear out quicker (since at half the width, it'll have half as much tread area to wear down). Since thinner tyres will experience that, very generally, the tyre makers run harder compounds in thinner tyres, and can 'get away with' softer compounds on wider tyres and still have acceptable tyre life. So in general, wider tyres 'might' grip more, but it's only because they were made with softer grippier tread, not just due ot the width all by itself. The reason I mention this is pretty simple - it is probably now obvious - it's not so much a matter of finding 'a' tyre in 225 or 195 or whatever the widest width is, the REAL trick is to look at each individual tyre in the sizes that will fit, and find the ones with the stickiest tread compound. Now, even people who compete in short sprint races can overcook their tyres, so you have to try and find a balance between tyre life, the traction you need, and how long they will be good for 'thrashing' around before they start to go off a little due to overheating. As a good example - this is why the smaller cars (relatively speaking) tend to do so well compared to the big ones in Improved Production - the tyre sizes are too narrow (relatively) for the bigger cars and they overheat after a couple of laps, so the drivers have to nurse them a lot more. They can't 'really' use grippier compounds, because the tyres/compound are a regulated item. But on a streeter, you can find a happy medium (if you are willing to go through tyres perhaps every 5-10,000km) So now on to chassis/suspension. One of the critical things (aside from axle tramp, and there's plenty of discussions on here about caltracs/anti-tramp bar fabrication and fitment) to do is to make the car's intertia help to push down hard on the rears when the car launches. TO do this, you need the front leaf pivot point to be higher than the axle centre line. then the leaf moves slightly 'uphill' toward the front. This is important because when the axle is pushed forward (as you launch) it'll try and 'lift' the car (since that slight angle translates into a slight upward force). So if it is trying to lift the car, then it has to do it via 'pushing down' on teh rears. The car won't (usually) actually lift up at the rear, instead as the rears push forward, the inertia of the car body/chassis tries to push rearward, and so this then pushes down harder still on the rear tyres. The car itself won't (when setup right) massively lift or squat down at the rear but the FORCE applied pushing down on the rear wheels will be maximised. The reason i bring _that_ up is that often if a car is lowered, you can end up with the axle centre line being higher than the front leaf pivot point. If that is the case, instead of it 'increasing' downforce, it actually 'unloads' the tyres and makes it easier for them to lose traction and continue not to grip. So you need to either have the car ride height set high enough at the rear to allow the front leaf pivot point to be higher than the axles, or if that is too high, you'd have to look at shifting the front leaf attachment/pivot higher up in the chassis (not exactly an easy option a lot of the time). At the very least, keep 'lowering blocks' well away from it. Aside from the lowering blocks setting the axle centreline too high, the further you raise the axle tubes up away from the leaf springs, the more 'leverage' the diff has to twist and wind up rthe springs, so it'll also increase axle tramp (which itself will compromise launches). The same thing applies to various 4 link/control arm rear suspensions, the math angles are perhaps a little different, but the overall principle applies. so as bad as it sounds, often the loss of traction is just as much to do with a car being 'too low' and ending up with undesirable suspension geometry as a result. When it comes to circuit racing, you'll find that you might end up wanting it a little lower than would be ideal for straight line, and as a result you'll get good cornering/mid corner speed, but might start to compromise corner exit speed as it just won't grip enough to leave the corner hard enough. TO that end, obviously you'll have to test and come to the best combination of mid corner vs corner exit speed and straight line grip off the mark. For most circuit racers, grip off the line isn't as important, as you only do that once - at the race start, so a lot of them sacrifice their launch potential for better lap times for the rest of the race. Obviously you can also look at stuff like less rear sway bar and or thicker front one (if they are fitted front and rear) to try and get better grip out of the corner (but it might affect turn in a little - hey everything on a performance car is a combination of compromises!). Additionally, you could also look at adjustable rear shocks, and in particular (if it is still too slippy out of a corner) look into softening the rear rebound damping. This will tend to make the car get more grip out of the corner, but ironically because it grips better and doesn't mildly oversteer out of the corner as much, it can actually 'feel' slower. But it will be quicker lap times (obviously experiment to find the ideal setting). What else - I highly recommend 'tune to win' by Carroll Smith. It discusses car suspension design and optimising for racing. Admittedly it is a few years old now, but 99% of the info in there is absolutely gold. About the only thing it doesn't have in quite the same detail as we might like is shock absorbers (it does discuss them pretty well though) and this is simply because at the time the book was written, fully adjustable shocks existed, but were miles away from the current stuff. Also - the tyres he discusses were race tyres of the era, and differ from street oriented radial tyres. The general info is all accurate, but the inflation pressures are night and day - street radials don't grip better with low pressures, etc. I'd actually recommend all of Smith's books. Drive to win is all about how to get sponsorship etc, as well as how to drive. It's also amusing in some parts. Tune to win is everything about setup/adjustment for optimal track times. Engineer to win is about race car construction - various metallurgy stuff, relative strengths/thicknesses of mild steel vs chromoly (for example, chromoly is stronger so thinner wall thickness can be used, but when it is in a collision, it is more likely to break and leave sharp edges, but mild steel will tend to flex/bend instead. So it can actually be safer, albeit heavier). He also did a book on nuts bolts fasteners. I've got the books. Someone mentioned to me that tune to win might be available as a torrent on bitsnoop, but I haven't looked and I absolutely am not suggesting or condoning any illegal download. Apart from it being 'unfair' in a general sense, I honestly reckon the books are so packed with info, that they are worth every dollar ten times over. Maybe someone out there might (hypothetically, but not in the real world) download the torrent, just to check it out, and then are so impressed by it, they purchase the book(s)
Some are available at the state library so if you have
a big library nearby its worth checking otherwise not
a big investment and beats any mills and boon novels
when you have a chance to sit down with a cuppa :)
Posted on: 2011/11/8 11:55
From Brissy
CA18 powered datto picking the wheels up in a huge way on a 205 radial and H patteren and still running a 10.4
Posted on: 2011/11/8 12:26
Not too shy to talk
a lot of technical info here thanks for the great read.first Id like to say that my answer here are just my interepretaion of the situation. Ive seen this tire vs traction before so heres my conclusion.
Ok so first things first I completely agree with you on this. BUT that BIG IF is REALLY BIG. WE all know in real world a lot of data does not always mean a whole lot in real world as it does in data world.
what I mean is data = non real world interferance SOMETIMES. For example roads are full of dust/dirt and so on. so a wider tire will be able to have more contact patch with solid cement vs skinnier tire that has smaller contact patch with solid cement. and we all know is is true because the streets arent prep lol
another would be on the rain, wider tire will be able to get more contact with surface vs skinnier tire.
with that said I think tire width In real world is a big deal here. wider tire = less over heating/ more contact(with solid surface) / (if as you say is true then also softer compound) so the result does say that wider tire = more traction.
ofcource compound is very important and if manufacturer really puts softer compound on wider tire vs their skinnier tire then the only way you can get acces to that softer compound is buying that wider tire THEN you get more traction with wider tire. Am I making sence? lol
ya but i think I mentioned before that I dont want to set it up just for straight line only and be a sloppy street car. I know im going to want it lowered and that may be "too low" to be efficient for traction. (which is why I was thinking of awd.
Posted on: 2011/11/8 19:01
Not too shy to talk
weight roughly 27xx my datsun would beat that car no problem on low boost. and im positive even with the same power to weight ratio my datsun will be faster.
but more importantly ITS NOT PRE 1975.
and not to mention finding one is going to be a mission
Did we even get those in the US?
Posted on: 2011/11/8 19:07
Not too shy to talk
im assuming youre refering to H pattern tranny?
what kind of radial? street legal?
and got any more info on that car or link? super interested lol
Posted on: 2011/11/8 19:11
From Brissy
I just found the info and pic on boostcruising and its in Queensland. Im not too sure about suspension setup. maybe someone else on here might know some more info.
looks to me that its a leaf spring rear end and maybe a caltrack or 2 link setup.
Posted on: 2011/11/8 20:27
Not too shy to talk
It just came to my attention that I will need something around 2-3k for a rear end set up to handle the power I want with r31 rear end or 8.8 or 9".
thats way to much just for my aim of 350-400whp.
any other cheaper option?
Im seriously considering doing a mid-engine mount set up instead if it will allow me to keep the back seat.
may be cheaper in the long run since I can build the mounts and stuff.
Posted on: 2011/11/8 22:34
From Brisbane, Australia
that simply is not true in the real world. EG I went from a 235 rear to a 255 rear in the same brand and compound of semi slick and had so much more rear grip that it changed the handling balance entirely. Your theory simply doesn't work in practice beacuse you left out the part about grip coming from the interlocking of the rubber and the road surface. The wider tyre has more interlocking due to the increased surface area, while only margineally less psi pushing it into the surface - they only need so much pressure to grip, and once you get to that point it's the law of diminishing returns - doubling the pressure won't double the grip. Its not a linear relationship. Wider tyres of the same type and compound do provide better grip.
this is a poor example. the IPRA control yokohama tyres come in softer compounds in the smaller sizes, giving the smaller, lighter cars an advantage.
Posted on: 2011/11/9 0:32
« 1 2 (3) 4 5 6 »
