Any one have a engine block sitting around with numbers on it.
From Narellan,Sydney
After a engine block just for the numbers for rego will never be used so after 1 some one wants to throw out
Posted on: 2012/6/15 10:58
Re: Any one have a engine block sitting around with numbers on it.
i have an A series early a12 block. It was pulled from the car a stripped to a block a while back.... has no.s on it, this what u after?
Posted on: 2012/6/15 12:05
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Yea mate that's it
Posted on: 2012/6/15 12:09
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
where are u located? im in melb.
Posted on: 2012/6/15 12:25
1200 Ute - Mild A12
That's a problem I'm in sydney
Posted on: 2012/6/15 12:28
bugger, talk to bige... he'll be able to hook u up
Posted on: 2012/6/15 12:32
1200 Ute - Mild A12
Ok thanks mate
Posted on: 2012/6/15 12:48
From Sydney, Australia
This is a googlle indexed public site, you need to be more discrete.
Posted on: 2012/6/15 14:38
From Logan, QLD
Seems the only reason you would do this would be because you stole a motor?
Posted on: 2012/6/15 16:43
Or if you want to register the car as stock although it has an illegal engine in it.
Posted on: 2012/6/15 18:22
