Re: Rectangle cluster to round cluster
From Brisvegas
i like those pens , i redone the badges on my old vl turbo with one , worked a treat
Posted on: 2011/6/25 13:14
1980 Datsun 1200 ute CA18DET
From Sydney, Australia
RE TACHO: Should say positive. You are right.
Can be wired in series or parallel. Series is simpler, but when tacho wire pulls off by accident, the engine stops.
http://datsun1200.com/uploads/photos/2708.jpg
Posted on: 2011/6/25 13:54
Glad to hear it's working. Yes, it seems nearly every wire in the round 12-pin connector needs to be moved to a new spot! not just a couple of wires.
Posted on: 2011/6/26 2:17
From Brisvegas
haha yep thats it , its not hard to do
Posted on: 2011/6/29 13:25
From Wellington
Going to have a try at this swap tomorrow, just want to know if the wires will pull out of the back of scocket or do I have to cut and rejoin, can someone tell how to do it....thanks
Posted on: 2012/5/19 9:03
I did some research on this and it seems there are three clusters:
1. Rectangle gauge
2. Round gauge (Coupe, Sedan GL, etc)
3. 1979-up ute round gauge
#1 and #3 appear to use the same wiring.
If putting #2 in place of #1, change two (or more?) wires around. See Instrument Panel Conversion section "Dash Changes for Sedan, Ute and Station Wagon"
When you are done, please tell us which wires you had to change around.
Posted on: 2012/5/20 0:41
From Wellington
I have been mucking around with this all day and now have most of it going.....
As standard the wires were ( the missing ones are the ones I pulled out and forgot to wright down) are as follows
1 yellow/ white
2
3
4
5 white/red
6 yellow
7 green
8 blank
9 green/red
10 green/blue
11
12 black
My car has two black wires and no blue, so it has been a bit confusing working to some of diagranes giving but most of the dash works with the wires in these places
1 yellow/white
2 yellow/black
3 black
4 red/white
5 yellow
6 white/red
7 green
8 blank
9 green/red
10 green/blue
11 green/black
12 black
Posted on: 2012/7/7 7:59
Be aware there are TWO round gauge clusters, each wired different
* 1970-1973 Coupe/GL round cluster
* 1978-up Ute round cluster
Posted on: 2012/7/8 2:37
From Wellington
My cluster is from a 1200 coupe so would be the early type.....ok its all in and running now, changed these wires
6 green
7 blank
8 white red
Posted on: 2012/7/8 7:32
Below are both rectangle and round variations of the wiring. I was pretty pedantic writing it all down but wouldn't bet my house on it. It did work for me though.
These are the wires from a Round Cluster (clock not tacho) that was taken from a ute being wrecked. I am unsure of the year.
1) Yellow/White (temp gauge)
2) Black (earth)
3) Green/Black (Right Turn)
4) Green/Blue (Illumination Lamps)
5) Green/Red (Left Turn)
6) White/Red (Charge)
7) Yellow/Red (Brake)
8) Green (12V)
9) Yellow (Fuel Gauge)
10) Black (Earth)
11) Red/White (Beam)
12) Yellow/Black (Oil)
This is the wiring from a Rectangle cluster removed from a '77 ute.
1) Blue/Green (Illumination Lamps)
2) Green (12V)
3) Green/Red (Left turn)
4) White/Red (Charge)
5) Black (earth)
6) EMPTY
7) Red/White (Beam)
8) Green/Black (Right turn)
9) Black (earth)
10) Yellow/Black (Oil)
11) Yellow/White (Temp)
12) Yellow (Fuel Gauge)
Posted on: 2018/6/18 11:53
1 x Baby Blue Ute
« 1 2 (3)
